Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Carbon veil covering
Reply
Old 03-05-2019, 10:11 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Carbon veil covering
I'm building a Tiporare pattern plane and want to do a painted finish. I've glassed a plane before with looking results. I'm thinking of going with .2 oz carbon veil applied with nitrate dope on this one though to save some weight. If I do the wings in carbon, do I still need to glass the center section? If so, should I glass it after applying the carbon? I'm also curious if carbon will go around the compound curves of the fuselage or wingtips?
jester_s1 is offline
Old 03-05-2019, 11:42 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jester, I did a set of pattern wings with Carbon veil once and it will be my last time. What I found was that it was much more difficult to apply as it would not conform to the leading edge or tips very well. Trying to form it to the compound curve would get tears easily. It required more bonding agent ( in my case Klass Kote clear ) and then it required more filler prior to primer. I figure it took me twice as long to do the job and I don't think I saved any weight. IMO the best system is going to be .75oz cloth applied with Klass Kote clear, light sand, mix up some Klass Kote primer with some micro balloons for a runny paste and smear all over the wing, allow to dry and hit it with some 320 grit. After that spray a coat of Klass Kote primer.
When it comes to glassing the center section, I like to overlap the 3/4oz cloth about 8", then apply a 6" strip of 3oz and 4" strip of 3oz. This will allow you to easily feather the center section. Do not apply the thinner strip first, this leaves a ridge at the edge of the thin strip and while feather sanding you will burn through the wider strip making the wider peice useless.
speedracerntrixie is online now
Old 03-05-2019, 04:59 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What did you use to adhere it? There is an old thread on here about using dope, which supposedly loosens up the fibers a bit to help it conform. Obviously, I haven't done it before though.
Old 03-05-2019, 07:56 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Klass Kote clear. I suppose it is possible that dope may make it a bit more workable but I doubt it. I didnt have issues with the binder not loosening up just that CF is not as pliable.
Old 03-13-2019, 05:09 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a thread in the pattern section about using silkspan and dope. Probably not as strong as glass cloth but the claim is it is lighter. I would think lacquer would work as well as dope. I would have to think there was some type of structure (carbon strips, balsa spars etc) under the wing to add some strength to the wing. I think that is pretty much SOP for pattern wings.
Ken
kenh3497 is offline
