Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Molding Problems
Reply
Old 04-22-2019, 03:06 AM
Typhoon Phil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Molding Problems
I've just pulled a set of molds from a plug.... plug was made with blue foam covered in 2 layers of 12oz cloth then filled and primed before rubbing back to 1200 grade wet. Then 6 coats of maguires mirror glaze applied before spraying on 3 layers of PVA release agent. The molds were made up of 2 thick coats of Durabuild surface primer and 8 layers of 12oz cloth.... the molds pulled away ok but in places some of the primer came away too which wasn't too much of a problem as it polished up smooth with no edges with rubbing compound but in a couple of other places some of the filler came away too which did cause a problem as it needed to be mechanically removed and has affected the surface finish....
Any thoughts to prevent this happening again?
Typhoon Phil is offline
Old 04-22-2019, 06:04 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use release products from the same company. I always use Partall #2 wax and Partall PVA. Usually the first coats of the mold surface would be a tooling resin of some sort. I use the same laminating resin throughout but the first two coats prior to cloth application is mixed with 5% volume by weight graphite powder. Your first couple layers of cloth should be fairly light weight, I start with 1.4oz then 3oz then alternate between 5.8oz and 12oz. Lastly, it is almost impossible to get a smooth finish by spraying PVA ( at least for me ), I apply PVA straight out of the bottle with a foam brush.
speedracerntrixie is offline
Old 04-22-2019, 03:33 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As mentioned above Partall #2 wax is the best. For a plug I will apply 10 coats waiting the full half hour between coats. I will also apply 10 coats to new molds for their first pull. You mentioned that you used primer for your mold. Perhaps others have had success with it... but it is much softer than using a tooling coat. The stuff was actually invented for this purpose. If you dont want to spend the money on proper epoxy tooling coat then you could do as mentioned in the above post.
I've tried paints before as a tooling coat but never had any success so I now stick with proper epoxy tooling coat.
Vettster is offline
Old 04-23-2019, 01:11 AM
Typhoon Phil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the replies guys..... when you say tooling coat, is that on the plug (as in the last layer) or on the mold, as in the first layers before the cloth? Sorry for the rookie query!
Old 04-23-2019, 05:17 AM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tooling cost is the first layer of the mold. It's very hard and won't pull apart. It's very thick stuff that's brushed on
Vettster is offline
Old 04-23-2019, 08:19 AM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mold interior following plus removal and a wash with soap and water.
As I stated above, I simply add some graphite power to my laminating resin and brush on two coats. I then run a strand of 12K CF tow in the corner and a paste of laminating resin with graphite powder and cabosil. Then start with light weight cloth. That is usually the end of day one. Day two is the medium weight cloth followed by the bulk layers. Building up the mold too quickly can create excessive heat that can affect the release system.
Old 04-23-2019, 02:38 PM
Typhoon Phil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Again great info... thanks..... I'm assuming you're using epoxy resin, so how do you prevent the wax layer building up at the end of day one? Surely if you take a break during the laying up of layers then you get a layer of wax forming which would induce delamination?
Old 04-23-2019, 04:00 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Epoxy resin does not contain wax like polyester does. However it's best not no go longer than 18 hours between applications.
