Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
FG Cowl Fabrication
Reply
Old 10-09-2019, 05:43 AM
cathurga
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default FG Cowl Fabrication
Hi All,
I hope this is the right place to ask this.
I am installing a radial engine in a large model, the engine diameter is slightly too large for the cowl, and I have to either make small holes for the rockers to poke out of, or find some other way of doing it. I was thinking of cutting the cowl in 3 or 4 places and just 'widening' it by a mm or so at each cut. I am wondering if this makes sense, and if anyone has any advice on how this can be accomplished or a similar plan, please say so.
I understand that the cowl will be slightly bigger, but I may cut cowl flaps so that it doesnt look as bad, and would allow more cooling.
Thanks in advance.
cathurga is offline
Old 10-09-2019, 01:36 PM
RCFlyerDan
My Feedback: (52)
RCFlyerDan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you thought about blisters on the cowling?
RCFlyerDan is offline
Old 10-09-2019, 02:45 PM
R8893
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cathurga,
I have not done as you are considering, but have seen it done on some number of internet builds.
R8893 is offline
Old 10-09-2019, 11:37 PM
cathurga
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dan, yes, that was an option, but a part of me says that a 'slightly' enlarged cowl might look less unsightly than blisters. Not only that, but given the tolerances, it may be difficult to install/remove the cowl with rockers having to squeeze through little holes etc. I like cowl installs to be done so that they are easily removable for maintenance works. I also dislike adding wieght to cowls as I often test fly planes without them.
R8893, if you ever come across one that you can think if, please let me know with a linkety link...
cathurga is offline
Old 10-14-2019, 07:09 AM
bentwings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you go with the split cowl, I’d suggest you make a couple rings to fit inside with a few stringers to keep then aligned. We call it a buck in the fab shop. This will help keep the pieces aligned and make glassing them back together much easier.
bentwings is offline
