Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Glue for fiberglass crack
Old 11-26-2019, 11:04 PM
mayhem3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Glue for fiberglass crack
Hello,
will gorrila glue be good for fixing a crack in a fiberglass fuselage? Thanks for your reply
mayhem3d is offline
Old 11-27-2019, 07:12 AM
RCFlyerDan
My Feedback: (52)
RCFlyerDan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, snap the pieces back into place and use thin CA. If you have some fiberglass cloth, cut a piece to cover the area on the inside. You can lay it in place and then use thin CA to bond it to the fiberglass. Or you can use some thinned epoxy. If it is small, the thin CA is the fastest and will strongly fix the crack. When applying the thin CA to the cloth, it takes quite a bit. So make sure that you stand back and not breathe any in. It may also smoke as it cures. Do not touch while curing, or you could end up with a chemical burn.
RCFlyerDan is offline
Old 11-27-2019, 08:48 AM
mayhem3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mayhem3d is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
