Info required re EPP
Anyone know where I can buy EPP foam sheets in UK? Also where can I find info/tips on cutting EPP. Can I use my poly foam cutting setup?
RE: Info required re EPP
Give you three good ones:
Foam cutter power supply plans: http://www.nsrca.org/technical/tip_t...wer_supply.htm
Foam cutter table plan: http://www.charlesriverrc.org/articl...gmancutter.htm
General foam cutting info: http://www.charlesriverrc.org/articl...ngsequence.htm
As to EPP, that's a bit dodgy really. It's not like the States where a decent Google search turns up some lot of companaies who have what you want. I found a few which may work, but you'd be best to ring them up directly. Here's what I found.
http://www.springvale.com/contacts/contacts.htm (Seems to be the best bet for locations and size options. Look at the Springvale Floorshield)
http://www.styro-tech.uk.com/ (Has CNC foam cutting services, but it's not geared towards plains.)
http://www.custompac.co.uk/index.htm (Has CNC foam cutting services, but it's not geared towards plains.)
http://www.simplipac.co.uk/contact.htm
