Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
repair to carbon fiber landing gear
Reply
Old 07-29-2004, 12:55 PM
petergordon
petergordon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default repair to carbon fiber landing gear
Just had a hard landing with my 33% cap and have delaminated the carbon fiber gear at the fuse bend. Can this be repaired? I looked through this forum and couldn't see anything on this topic.
Peter
petergordon is offline
Old 07-31-2004, 10:54 PM
Spastic
Spastic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: repair to carbon fiber landing gear
without adding some layers its tough, i would drill it full of 1/16 holes at the delam and then saturate the area with laminating epoxy, then grind/sand the area smooth and then add a few layers to the gear at the delam spot and then vacuum bag the whole works to get the added layers nice and tight, it could be done without looking to crappy..
anybody have a better idea?????
Spastic is offline
Old 08-05-2004, 07:00 PM
Ed Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From the previous post.
Replace it with an aluminum gear.
Ed S
Ed Smith is offline
Old 08-05-2004, 08:00 PM
rctrax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't found any good aluminum gear since Halco quit making them If someone knows where one can get a GOOD aluminum gear I would like to hear of it.
rctrax is offline
Old 08-21-2004, 06:30 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rctrax
The problem with aluminum gear is that everyone is using 6061-T6 and should be using 2024-T3. But its more expensive and harder to find..
Roger
Forgues Research is offline
Old 08-21-2004, 08:55 PM
XJet
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd opt for 7075 over 2024 for this application.
I use 2024 when machining parts that don't need anodizing (it machines like butter) but I almost always use 7075 for applications such as undercarriage legs, wing tubes, etc. 7075 has the advantage that you can anodize it -- a nice set of UC legs with a deep lusterous finish that matches your bird and spats looks so nice :-)
XJet is offline
Old 10-02-2004, 10:23 AM
Bryan Rockoff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
But where can I order a "good" landing gear premade? I'm not able to do the machining.
Rox
Bryan Rockoff is offline
Old 10-02-2004, 10:24 AM
Bryan Rockoff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
(added so I get an email notice when someone replies...)
Old 10-02-2004, 10:27 AM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bryan, you could try http://www.graphtechrc.com and http://www.tntlandinggear.com
rajul is offline
Old 10-02-2004, 10:57 AM
Forgues Research
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: XJet
There are different paints that you can use to get the same results.
Roger
Forgues Research
