Wax only?
Wax only?
I know this has been discussed before but can I use partall wax alone on a plug to pull a mold off of? I would prefer to do as little buffing as possible on the finished mold. It seems a waste of time to get a perfect mirror finish on my plugs and then get a textured finish from the PVA. I know you can use wax only on a mold once it has a few parts pulled off of it. Thanks for your input.
Tom
Tom
RE: Wax only?
Yes, you can use wax only... and Partall is a good wax. It's important to follow directions and apply 6-10 coats. Don't apply one or two and then wonder why something sticks.
You can also get a very good finish with PVA if you apply it correctly (airbrush). Wax only is easier and more convenient in many ways, however.
Good luck,
-David
Good luck,
-David
MD,
RE: Wax only?
Dolphin Wax.
I only did 4 coats, let it sit over night, laid up the part, and it came right off...
If I had to use PVA, I don't think I would ever mold anything...
j
j
MN
RE: Wax only?
I used 6 coats of dolphin wax, and a layer of PVA and I still had a couple of areas stick on my first piece. I know I did a good job with the wax, but it still stuck a little here and there.
I was able to get a pretty smooth coat of PVA down, by building it up slowly with 4 really lite coats with my HVLP gun. I painted in the mold also, and the finish came out very good.
My Feedback: (18)
CA
RE: Wax only?
I've used Partall only (no pva) on a set of molds.....One coat and no problems. I pulled 11 fuselages and rudders. When buffing the wax to a shine, it's likely that some of the wax can be removed and/or one can't tell the difference between where there is wax and where there is not. I had a small area stick once when the wax was polished to a shine before lay up. However, I tried a different technique that gave me the best results and was the fastest when using only one coat of Partall (no pva)........I applied the wax in a thin coat so it was still cloudy and didn't polish it at all...this way the dull finish assured there was wax everywhere that looked dull/cloudy. The parts came out easiest I've seen and the finish was very smooth as before.......I can send pictures of the fuselage if anyone is interested.
Amir
Amir
RE: Wax only?
Thanks for the input everyone.
AmirN if you left the wax cloudy what was the finish on the part like? Pictures would be great.
Tom
Tom
My Feedback: (18)
CA
RE: Wax only?
Tommyboy1229, the finish looked just as smooth as a polished mold surface. The wax was left cloudy, but spread thinly and evenly without any lumps or bumps.....I'll figure out how to post a couple of pictures here soon.
Amir
Amir
My Feedback: (18)
CA
RE: Wax only?
Here's a fuselage and rudder.........and a built plane from a customer. It was a fun project I did with Michael Luvara, who owns the molds and made them too. The plane was offered as a kit; fuselage as you see it, foam cores, canopy, plans and instructions. I think Michael has a write up some where on this site about Tsunami.
Have fun,
Amir
Have fun,
Amir
RE: Wax only?
Yeah, ok... leaving the wax hazy might be ok when you're sanding/priming/painting after you pull the part, but I like to paint the parts in the mold... so the finish of the wax (or whatever) in the mold is exactly what I'll get on the finished part. I like to see my reflection, in other words.
-David
-David
RE: Wax only?
I know what your saying David. I would like to paint in the mold, but I don't know if my parting lines on these particular molds are sharp enough.
Tom
Tom
