Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Reload this Page >
Sources of PVC foam !! help please !!
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 10-07-2004, 01:00 AM
fdo300
fdo300's Avatar
Default Sources of PVC foam !! help please !!
Hi
Does anyone of you know what density of PVC foam does Composite-ARF use on their airplanes to make the composite sandwich used on wings and fuselaje ??
Where I can buy some ?
Best Regards
Fernando Viollier
Old 10-08-2004, 07:37 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Default RE: Sources of PVC foam !! help please !!
Fernando, you could try Sintra PVC foam sheets. Do a search and you should find a few suppliers
Old 10-09-2004, 10:28 AM
Goggles
Goggles's Avatar
I've looked all over for a product called Herex which is what many manufacturers use in Europe and I belive it is what CA uses. I can't find it any where in the 1/16" or 1/8" thickness any where. If you find some let me know.
I did try a product that was a PVC type, I think it was called Sintra but I'm not 100% sure about it. The Epoxy wouldn't stick to the sample pieces I had so I threw them out and the 1/16" piece I had was dificult to bend and wouldn't have worked.
Old 10-13-2004, 10:35 AM
fdo300
fdo300's Avatar
Thanks for the info
I have been searching on the web and I found a few sources of PVC sheets but nobody make them on 2mm tickness.
I will try to contact composite-ARF directly.
Regards
Fernando V.
Old 10-13-2004, 10:37 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Fernando, good luck and let us know what you find
