cnc router
RE: cnc router
If its 2d cutting, try your local signmaking shop. Most of them are set up for this pretty good. I had these aluminum honeycombing jigs made from autocad files a few years back & the price wasnt too made (considering the Armstrong Alternative). If its 3d profiling, most likely a different ($$) outfit altogether.
PA
RE: cnc router
Scott,
Let me know what it is and I may be able to CNC it on my mill 2D or 3D. I have played around some cutting a foam plug to make an engine cowl, and I'm getting ready to make some floats out of foam and then glass them. You can e-mail me or post it here.
Pete
Pete
RE: cnc router
ORIGINAL: ryancbr
ptxman,
Your wing looks great. How do you get your bow through each of those holes? (assuming that its hot wired)
ptxman,
RE: cnc router
PATTERNPILOT-
If you are looking to do a lot of CNC work you may want to set up your own machine. Check out the following that I came across. I can't vouch for anything, just simply remember seeing it once.
http://www.houstonhobbies.com
They may have something you like, or not. Worth a look anyway.
Bruce
Bruce
