Fish eyes in dope on fiberglass
My Feedback: (13)
MI
I have been having a terrible time with fish eyes on my fiberglass cowl and wheel pants. I have done everything I can think of to clean the surface. Sanded it with paint thinner, wiped it down with dope thinner, washed it with degreaser, etc... I still get fish eyes. My question is two fold. First, is there any other way to get rid of whatever it is that is causing this? I suspect it is some kind of silicone mold release. Second, can I use an anti-fish eye additive like "Smoothie" in dope?
Andy
Andy
My Feedback: (14)
TX
RE: Fish eyes in dope on fiberglass
It could be silicone that is the problem. Have you tried spraying a coat of clear on first and letting it dry for 24 hrs? If you can find a compatible primer that might help also. As for the anti fish eye additive the best thing is to mix up a batch and spray it on a test panel. It will either dry as normal or it wont so there shouldnt be a middle ground problem.
The last dope finish I did was 10 years ago on my yellow Aircraft P-47. The glass Fuselage and cowl took the Sig Olive Drab dope with no problem.
ORIGINAL: woodys3b
Andy
Andy
My Feedback: (13)
MI
The only spraying has been sandable primer from a spray can. Used that and automotive spot putty to fill pin holes. After that I have been brusning on coats of Nitrate dope. The last coat was color butyrate to make the fish eyes more visible so I know where to clean. Lots of sanding between coats with various cleaners/solvents to get rid of whatever is causing the fish eyes. I'm about to the point of stripping it down to square one and starting over. I've never had this much trouble with a fiberglass part in the past.
Andy
Andy
