Cutting and Handling Cloth
My Feedback: (42)
TX
Here is a technique I use to measure, cut and handle cloth prior to the layup process. Works for me, YMMV.
Get yourself a roll of 18" wide Reynolds freezer paper from the grocery store. I pay $5 for a 150 sq ft roll.
Lay down strips of paper the width of your cloth, and lightly mist them with 3M-77 on the plastified side. The less glue the better. Allow to dry for about an hour.
Unroll your cloth so it is flat and square, and paste the tacky paper down on the cloth. Smooth out the bond using a wide squeegee.
You now have a markable surface to measure and draw cutting lines using a pencil or marker. The bond keeps the edges of the cloth from unraveling during the cut, and through further handling.
The paper easily peels off - Have a corner or two turned up in advance so it is easier to start with gloves on.
AFAIK, none of the glue transfers onto the cloth - All of it stays on the paper. I have used this trechnique with various densities of fiberglass, Kevlar, and CF and it works great!
AK
Good tip! Thanks.
Previous Thread
Next Thread
