Seam line filler
CA
Seam line filler
I accidentally cut one half of a fuselage below where the seam line should be. I joined the 2 halves with tape, but now the outside has a noticeable notch where I cut it to low. I would like to fill it with something that will leave it roughly the same color (just clear epoxy) so its not as noticeable. Any ideas?
RE: Seam line filler
ORIGINAL: ryancbr
Thicken up some epoxy with colloidal silica (cab-o-sil, fumed silica, etc). It changes the color less than microballoons or other fillers.
