If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    JDHammer's Avatar
    Join Date
    Apr 2002
    Slippery Rock, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Reinforcing Wing Spars with Carbon Fiber
    Hi, here's my example: 84" wingspan, 22lb, all wood, built up unlimited aerobat. You want to strengthen the spruce spars with carbon fiber tapes running along the spar.
    Questions: Best way to bond CF to spruce (CA?). And also, where to apply CF (Top and Bottom?, Front and Back?). One more- thickness of CF for the aircraft example above? (Assuming we don't want to add too much weight.)
    Wonder how many "Gs" this aircraft could absorb after being properly reinforced?
    Thanks for the help, JD
  2. #2
    Join Date
    Dec 2001
    Oviedo, FL,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, since no one else has answered yet, I'll step up...
    Use the carbon strips on the top of the top spar and the bottom of the bottom spar. I'm thinking around .010 on bottom and .020 on top, thicker on top because CF and spruce are weaker in compression than tension. Glue it on using a good laminating epoxy like West Systems. Use balsa end-grain as shear webs between the spars. Wrap the spar assembly tightly with kevlar tow spacing the wraps about 1/8" towards the root, 1/2" towards the tip. Brush a thin coat of the epoxy over the whole thing.
    Build it like this and the stab will fail before the wing does
  3. #3
    JDHammer's Avatar
    Join Date
    Apr 2002
    Slippery Rock, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks R.C. , that's exactly the information I needed. Sounds like you could use the wing for a diving board after that treatment. I'll give it a try.
  4. #4
    Join Date
    Jan 2002
    Piqua, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    R. Carver seems to have a good system.
    I can only make one comment, use the lightest weight balsa square stock that you can find for the spars instead of the spruce, and put one layer of the uni tape on the top and bottom of each of the spar.
    Then continue with R. Carvers method, just go very lite on the epoxy!!! This is still overkill, but it will be very light and you will be battling weight with a bipe.
    My 2 cents,
    Darrin C
    \"Make everything like your going to make the front page of NASA Tech Briefs\"
    Go Team Orange! Darrin R Cash
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
