Carbon Fiber interfere with receiver?
Sorry, this has probably been asked many times, but I am planning on running the antenna inside the wing next to a cabon fiber tube spar. Is this an issue?
MN
RE: Carbon Fiber interfere with receiver?
Carbon Fiber near your antenna can definately reduce your range. However, I've found in a lot of cases you are just fine.
The trick is to do a good range check with your specific installation and see how it goes.
