Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Alternative to Bondo ???
Reply
Old 10-17-2005, 10:50 AM
2timmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Alternative to Bondo ???
Can anyone tell me if there's a product like "Bondo", that' s just as good and strong, but dosen't have all the health issues related to it? We have students presently using 'Bondo" to fill inlarge voids, but when their mixing it up, the air becomes unbearable. We cannot afford to properly ventilate the area, so I was hoping that there was an alternative.
2timmer is offline
Old 10-17-2005, 02:29 PM
rcalfred
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Alternative to Bondo ???
Bondo is basically polyester resin with fillers in it. That is why it smells so bad. As an experiment you could try mixing epoxy resin with phenolic microballoons. They make a mixture that is relatively easy to sand and you wouldn't have to put up with the smell. I get my balloons at: http://www.shopmaninc.com. They are in Florida. Regards.
rcalfred is offline
Old 10-17-2005, 02:58 PM
2timmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Thanks Al". I will look into that.
2timmer is offline
Old 10-17-2005, 04:17 PM
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Be very careful. Epoxy does not emit as strong an odor as polyester does. This does NOT mean that the fumes are less toxic. Adequate ventelation is a necessary when working with epoxy as well.
I actualy use another polyester based product called Glase Coat. It sands easier than Bondo, which in turn sands much easier than epoxy/microballons. Of course, you should use dust masks when sanding either of them.
dreadnaut is offline
Old 10-17-2005, 04:27 PM
DHG
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Roger that. "Glaze Coat" by Evercoat. You can throw in some microballoons or cornstarch to make it fill faster and sand easier, plus a few drops of thinner to make it spread farther. Mask, gloves, and ventilation are ALWAYS required.
DHG is offline
Old 10-18-2005, 05:18 PM
Deadstik
My Feedback: (8)
Deadstik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2Timmer,
I use a product called "Icing" to fill any voids I may have. This is a polyester based product but for some reason adhears very well to my epoxyglass fuselages. It is super simple to sand and gives very good results.. I buy it at the local CarQuest auto parts store in the auto /paint section. As everyone here has suggested... all of these products require proper ventilation. There are many ways to accomplish this as in with temporary fans/ducting and I believe you need to look at that path. I think we are just now starting to find out what all of the "chemicals" of our youth really did to us. I don't even want to think about some of the stuff I have used without gloves/ventilation/protection... but.. I did quit smoking so.. One for me... good luck, but try the icing, much easier than Bondo, smells a little bit less.. but you still need to take care of the ventilation issue.
Dan
Carolina Custom Aircraft
Deadstik is offline
Old 10-26-2005, 01:10 PM
c130nut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another product I in place of Bondo is Dolphin Glaze. You can get it in thick or thin. Check with your local bodyshop supply store.
c130nut is offline
Old 10-26-2005, 04:56 PM
bruce88123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.por15.co.nz/UPOL_%20Produ...phin_glaze.htm
http://www.por15.co.nz/Data%20Sheets/u-pol.htm
I've/my company bought paint stripper from these people before. Good company.
bruce88123 is offline
Old 10-27-2005, 06:40 AM
2timmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone for your input it's very much appriciated. I've gone to various auto body suppliers and they don't sell 'Dolphin Glaze", so, before I go and order some on line, could someone please tell me if it's pretty smelly, and has to be mixed in a well ventilated room as there are administrative offices close by, and I don't want the fumes in their offices.
Thanks again to everyone for your input.
Regards
2timmer is offline
Old 10-27-2005, 07:38 AM
bruce88123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Call their office 450-465-5887 in St. Lambert (Montreal), QC or
email at www.por15canada.com for this info.
Note: This is for the POR15 products. They should be able to help with more info though.
Old 10-27-2005, 07:57 AM
2timmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bruce, I'll give them a call
2timmer is offline
Old 10-30-2005, 10:42 PM
David Searles
My Feedback: (49)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Auto body stores also carry a product called Split Second Rapid Sanding Glazing Putty. Try it, You'll LOVE it.
David S
David Searles is offline
Old 04-30-2006, 07:44 AM
speedster 1919
speedster 1919's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know this is an older topic. I sell these products for a living. Bondo is talc powder and polyester resin. All the glazes mentioned are just spin off products of a premium resin and less talc to make them thinner and creamier. The fumes are not that harmful. I have only encountered a few guys in 33 years that were allergic to bondo type products and became a little more health issue. Wear a good dust mask . Auto body men live just as long as average from what I've seen.
speedster 1919 is offline
Old 05-01-2006, 10:27 AM
2timmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Speedster, I'm going to check into this one.
2timmer is offline
