Carbon Fiber Bulkheads and Radio Interference
Does anyone have any experience with using carbon fiber reinforced bulkheads in a fiberglass fuse? Have you experienced any receiver interference when using carbon fiber?
Re: Carbon Fiber Bulkheads and Radio Interference
Chad
Are you using PCM or PPM equipment? I was thinking of substituting some plywood parts in my 50% CAP 232 with CF plates (laminated from balsa core and CF). I am trying to save some weight so I'll have to make up some samples and weigh them to see which is lighter the 1/4" ply or the CF/balsa plate. I don't want to use too much CF as I have heard that it can cause radio interference.
the Carbon is a conductor but, not as good a conductor as most metals. If a metal part in the same size and shape as the carbon wouldn't cause interference, neither will the carbon part. Usually conductors don't have much affect on signal strength unless they are connected electrically to the receiver circuitry or of a length that resonates at the receiver frequency. I have run the antenna of my receiver down the inside of a carbon fiber tail boom tube without any appreciable decrease in range. It is easy enough to check. Just do a ground range check with and without the carbon part and note the differences in ground range.
Chad
Chad
