color pigment for epoxy gelcoat
Hello everybody,
I wonder if anyone know what kind of gel coat materials are used in all-mold epoxy-glass gliders like the Nemesis 60" slope racer. the wing servo cover of my Nemesis got damaged and I am planning to made a replacement by myself. The original cover is dark blue in color and the gelcoat was sprayed on as I can clearly see dotted patterns when holding it against strong light. What amazes me is that although the gelcoat is extremely thin, the opacity is very high.
I have tried to make the gel coat by mixing color pigment ( in paste form ) into West System epoxy 105 resin/206 hardener but before the original opacity is attained, the dosage of color pigment is already so high that the cured resin becomes unacceptably soft.\
Can anyone offer some suggestions on materials that I can try ?
Thanks in advance ,
Y C Lui
Thanks in advance ,
Y C Lui
Re: color pigment for epoxy gelcoat
Thanks in advance ,
Y C Lui
Thanks in advance ,
Y C Lui
Adding pigment to the layup epoxy gives only yields a translucent color & is further affected by the color of glass/kevlar reinforcement cloth. Gel coat is less preferrable for flying components IMO because it is heavy & adds little strength. Gels are used for minimizing cloth print-through but you can control that aspect with a light cloth like 0.7 - 1.4 oz against a pre-paint surface with negligible surface effects. Furthermore, the painted surface can be wet sanded & polished carefully for an outstanding finish.
Prepainting molds & related (wax) releasing agents have been discussed here on rcu. Check the link below which gives some background & a link to H&M Racing. They supply a super wax for this application which I use & works great. There is nothing else like it that Ive found.
http://www.rcuniverse.com/showthread...hreadid=278002]
My Feedback: (7)
HI,
If you are trying to make an epoxy gel coat you must add a thixotrophic additive otherwise all you get is colored resin. Not sure where you would get it in the US though.
