green drillable fibre reinforced plastic?
AR, PUERTO RICO (USA)
does anybody know what thisa stuff is called? i saw a link here somewhere and a guy was using it to build engine mounts. and carb blocks for weedeater engines
it comes in sheets, rods etc and in different thicknesses. and i think mcmaster carr sells the stuff i want to call it fr4 or fp4 but i do a search and get nothing good
help
thanks
help
thanks
RE: green drillable fibre reinforced plastic?
well, from what you've described that sounds like G10. I don't know much about it except that it is similar to the stuff they use in PC board?? it can also be used to make control horns (that is, only if it is the stuff i'm think it
Chris B.
Chris B.
