Newcomer to Carbon Fiber world.
I have recently bought an IMPULSE F3A from BN Models and I am now going through its covering and assembling. The plane fuse is fiber glass finished with carbon fiber all the way from nose to tail; such as servo tray, landing gear reinforcement, firewall, ect...
My questions are:
1 - How would you screw the servos and other parts to the Cf sheets and make it secure? Any tip here?
2 - In case I had to drill a hole, how could I avoid cracks and broken chips through such a stiff, yet fragile, material?
Thanks and Cheers
My questions are:
Thanks and Cheers
CA
RE: Newcomer to Carbon Fiber world.
The best thing to do is drill and thru-bolt anything your looking to attach to the carbon plate. And, the best tool to drill carbon plate is a solid carbide drill-bit. They are also very expensive. But I would imagine you are talking about some smaller holes- maybe in the .125" range, and small carbide bits are not that much.
Brian
Brian
My Feedback: (18)
GA
Of course there are always several way's of doing things...Here is my input
Typically you'll drill the hole undersized and then step it up with a reamer...
At home I will typically "back the hole up" with a block of wood while drilling with a carbide twist drill...Then finish up finish with a reamer...
At work we use Dagger Drills...Of course we are dealing with allot thicker laminates than you'll ever see with the R/C stuff...The hole is drilled undersized and stepped up using a reamer...
I havn't invested in any Dagger Drills for my home projects yet...But I will eventually...They are wonderful...But sorta expensive...
I just did a real quick Google search...Here are a couple of links you may find interesting?? (If I find any better ones..I'll post them later)
http://composite.about.com/library/weekly/aa991028.htm
http://www.daggerdrills.com/servlet/StoreFront
http://www.gandtrack.co.uk/html/carbon_composites.html
