Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Fiberglass How to: Plug to Mold to Parts
Reply
Old 11-26-2007, 12:29 PM
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fiberglass How to: Plug to Mold to Parts
After several months of drawing (fifteen minutes at a time on the lap top while riding the commuter train to work), I have finaly ''gotten phyical'', and started on my plug.
ID:	812561   Click image for larger version
ID:	812562   Click image for larger version
dreadnaut is offline
Old 11-26-2007, 12:33 PM
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pictures.
ID:	812568   Click image for larger version
ID:	812569   Click image for larger version
Old 11-26-2007, 12:37 PM
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One half of the plug is almost done. Planking is a pain, but the results are pretty good. Still a lot of sanding and filling to do.
ID:	812571   Click image for larger version
Old 11-27-2007, 01:44 AM
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks Nice! Should make a great plug. Keep the pictures coming. I am going to post more on the copter project tomorrow.
DocJones199 is offline
Old 11-28-2007, 12:22 PM
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After the resin cures, the surface can be rough sanded to knock down any loose fibers.
Here is another installment in this project.
Once the surface of the plug has been cleaned up with coarse sandpaper, I can examine the pieces and decide where to go with this plug from this point. I began this plug imagining depressions with well defined edges where the windows should be. At this point, it seems that following this course will make this plug much more difficult to complete. This being the case, I have decided that the next phase of this plug build will see the side windows smoothed flush. Flush windows will make building the mold and pulling parts from the mold much easier.
After the rough sanding is complete, I can apply bondo to smooth out the surface of the helicopter. I only mix enough bondo that I can use in a few minutes. By mixing a little less bondo than I can comfortably work with, I am able to be much more efficient from a number of perspectives. First of all, I have time to work the bondo on the surface since I am not rushed by the thought of unused bondo curing on my mixing surface. Secondly, when I mix too much bondo, I end up just piling it on only to have to remove most of it later on because of sloppy application.
Old 11-28-2007, 02:05 PM
  #31
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree about the complexity of indenting the windows. Been there, done that, pulled out a lot of hair over it.
I plan to do panel lines on mine. I had tried this before by scratching them into the surface. Never Again! I have heard of doing it by masking, then painting it so that the masking lines do the job. This might work for your windows too.
Rivets anyone?[X(]
Old 12-01-2007, 10:36 PM
  #32
senna12625
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rivets anyone?[X(]
dreadnaut... rivets are a simple matter... albeit tedious and requiring a bit of practice. Most scale builders use Titebond III and a syringe. Mark the rivet schedule on the plug and daub a metered amount of glue (practice on scrap just before you do the plug will let you get the hang of the metering) at those schedule locations. Keeping the tip of the syringe as vertical as possible helps to make the glue meniscus more circular. Allow the glue to dry completely before primer and final paint. Voila...! Rivets!!!
senna12625
senna12625 is offline
Old 12-05-2007, 10:40 AM
  #33
funkworks
funkworks's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh no... i have a composite bug bite and the infection has almost reached my hands! haha!
great job on the plugs guys... one question though... Ive been kicking an idea around in my head. I want to build a 1/12 scale U-2. I plan on using an electric ducted fan set up and decided to make a composite fuse. This will be my first atempt at making a large fiberglass part so Ive been reading all I can get my hands on regarding fabrication. As far as making a plug, i noticed you guys are making your plug in 2 halves... Im assuming you will be making your moulds and parts separately then. In other places Ive read about making a single mold and then using a parting board to pull moulds from each side... have any of you guys tried this??
funkworks is offline
Old 12-05-2007, 11:39 AM
  #34
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: funkworks
I noticed you guys are making your plug in 2 halves... Im assuming you will be making your moulds and parts separately then. In other places Ive read about making a single mold and then using a parting board to pull moulds from each side... have any of you guys tried this??
That was my original plan. A one piece plug w/parting board is the usual way it is done. It is very difficult to get the pieces to match up properly if the plug is made out of separate pieces. I had an idea of how to do it, and get it to work, but as work is progressing on the plug I am running into snags in that plan and will probably join the halves together and use a parting board.
I will add pictures this weekend, but I have allignment pins in the halves of the plug. I was going to join them, and shape them. Then I was going to set the half with the alignment holes on a flat board, and layup half of the mold. Then I was going to place the half with the alignment pins on this, and lay up the other half of the mold.
The problem is that as I was planking the plug, the mating faces moved a little and do not lay perfectly flat against each other. I will probably glue them and clamp them while the glue dries. Next time I try this, I will try to make the profiles out of balsa so that they can be ''lap sanded'' flat after planking. I will also consider using flower shop foam instead of planking to reduce stress.
Notice also that I am not making separate plugs for the canopy and cowl. It is my intention to put the one piece plug in a parting board, then erect ''fences'' around the canopy and cowl. Lay up one side of the mold, remove it and ''fence'' the other side, lining up the fences with the ones on the first side. Lay up the second side, remove the fences, then lay up the canopy and cowl molds. This should ensure perfect fit of the parts.
Old 12-05-2007, 03:03 PM
  #35
funkworks
funkworks's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the reply. Sorry about the problems youre having but it sounds like you got a handle on them now...
Im working on drawings for a U-2 with about an 8-9 foot span. I think I can use an electric set up with a 5" fan since I probably wont need that much power to get her in the air. Im starting to see EDF set ups with 10+lbs of thrust now. I plan on making molds for the whole plane including wings and fins. I want to mold the fuse sides and vert fin together if possible and was worried the long fuse would give me alignment problems if I tried to make the molds from separate plug halves... Im still gathering reference material so I can start on the drawings...
Old 12-05-2007, 03:33 PM
  #36
ByLoudDesign
ByLoudDesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has any one ever used tooling wax sheets to get panel lines. It comes in various thicknesses and shapes with just a little practice to about any shape you wish. I have used them for depressed lettering, and to get a 12" clean edge on a deck mold for a 65" power boat to end the non-skid pattern. It is a one shot thing on the mold as the wax sometimes stays in the mold. but you could even press in rivet lines. I am thinking of doing this on my Goshawk. Make the plug 1/8" shy and overlasy the tooling wax sheet, put in rivet lines panel breaks and the like and then, carefully make a left and right mold of the paneled areas of the fuselage, turtle back and bottom panels. CST sells .007, .015, .02 and .062 thicknes.
http://www.cstsales.com/mold_making_supplies.html
ByLoudDesign is offline
Old 12-11-2007, 09:17 PM
  #37
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At this stage of the build, the project gets a little tedious. Sand, prime and fill – sand, prime and fill. This process is repeated over and over until the surface is smooth and the two halves join in the center.
Spending time at this stage pays off in the end. Remember that every flaw that you are too lazy to work out of the plug at this point will have to be worked out on every piece you ever make with the final mold. In other words, you can fix a flaw once here, or you can fix it on every piece you ever make, maybe 100 times. Do yourself a favor – Fix It Now!
It is at this time of a plug build that I like to apply a nice thick coat of heavy fill automotive primer from my air gun. This primer will fill all of the remaining imperfections and it can be fine sanded, polished and prepared for the actual molding of the plug.
At this point, I believe that I am done with the helicopter plug. Now is the last time to stare at it and make sure it is right before molding. As you can see in the picture, the two halves of the plug are clamped together so that I can check the alignment. I have already painstakingly aligned the two halves but now I am reaching the point of no return. I spend a good bit of time looking at the alignment of the two halves and at the plug itself.
ID:	823821   Click image for larger version
ID:	823822   Click image for larger version
Old 12-11-2007, 11:55 PM
  #38
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good. Mine is getting filled, and I hope to glass it this weekend.
Old 12-12-2007, 02:55 AM
  #39
g_boxwood
g_boxwood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice work on that plug Doc!
I'm looking forward to your tutorial, I'm waiting for your parting procedure description as I need to improve it myself!
Thank you for sharing!
g_boxwood is offline
Old 01-09-2008, 11:25 AM
  #40
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I have been absent from this tutorial. I found out that my pop has cancer - from smoking - been dealing with that.
Moving on to the tutorial...
I spend a good bit of time looking at the alignment of the two halves and at the plug itself to make sure that it meets my expectations. I notice obvious departures from my reference model and need to decide if I can live with the variations. Remember what I said about my expectations of model building at the beginning of this manual – I like my projects to look like what they are supposed to look like but I don’t expect them to be completely scale. Keeping that concept in mind, I can easily identify this as a Huey UH-1 so I am good with what I have in this plug.
Preparing the plug is the next stage of this build. I begin by mounting the two halves of the plug to a piece of inch thick MDF board. I attach the plugs by using screws from the back side of the MDF. Some people glue or epoxy their plugs to the parting plane. I prefer to use screws because I can remove the plug from the MDF after the mold is finished with out destroying it.
Once I have the plugs securely attached to the parting plane, I need to go around the base of the plugs looking for gaps between the board and the plugs. Any gaps are filled with clay. This is just a matter of forcing the clay into the gaps in order to prevent resin from getting under the plug. When the gaps are filled and all excess clay is removed, I can apply mold release wax to the plugs and the MDF parting plane. I like both McGuire’s and Part-All mold release waxes. It is important to apply at least five coats to the plugs in order to ensure adequate coverage. The plugs should be polished to a shiny smooth finish.
Old 01-19-2008, 08:53 PM
  #41
Constrictor
My Feedback: (46)
Constrictor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a question, ive got a glass cowl i want to duplicate, can i make a mold of it without destroying the original cowl? and would i want to paint the cowl up nice and smooth or just put my wax and mold release strait on the bare glass of the cowl to be duplicated? would the original cowl be ruined for future painting? if i did paint the cowl to make a mold off of, would i have to worry about the paint comming off when releasing the mold?
Thanks for looking at my questions
Constrictor is offline
Old 01-20-2008, 02:39 AM
  #42
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there,
You should be able to pull a mold directly from the unpainted cowl. Just make sure to wax it good and get a few coats of PVA on it. It should be fine. You can paint the cowl first but it may get ruined during the de-mold. You can definitly paint it after molding. You have to be sure to remove all the wax before painting. Good luck with that.
Old 01-20-2008, 03:18 AM
  #43
g_boxwood
g_boxwood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Constrictor
[...] and would i want to paint the cowl up nice and smooth or just put my wax and mold release strait on the bare glass of the cowl to be duplicated? [...] if i did paint the cowl to make a mold off of, would i have to worry about the paint comming off when releasing the mold?
Painting or not the cowl depends on how good its bare-fiberglass-finish is! If it is smooth, glossy and with no air bubbles or defects it could be treated straight with release agents, otherwise you'll need to fill it, prime it and give it a shiny coat of paint, possibly 2-part...
If the paint system is properly applied (which is easy) .AND. if the release agents are properly applied (which is harder) you shouldn't worry about the paint chipping off the cowl upon demolding.
You should consider, as Doc already said, that painting the cowl you used as a plug may be more than a concern: treat it with solvent cleaning products (those especially formulated to remove release agents residues) or wet-sand it to its roots...
One last thing: it may be necessary to stiifen the cowl if you intend to use it as a plug. You could add some bulkheads inside it (those bulkheads may then be grinded off if you want to use that cowl again) or you could use 2-part foam (which you won't be able to remove any more): the choice is yours!
HTH,
Old 01-20-2008, 08:23 AM
  #44
Constrictor
My Feedback: (46)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the information guys!
Old 01-24-2008, 01:45 PM
  #45
analucius
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Doc,
This is a very interesting project as I am doing a glider fuselage for a 100" glider in fiberglass. See the screenshots from my CAD in the attached photos. You may also see the 3 view of the project. It's a Dave Jones glider called R-2 from the 80'ies, which I am updating with numerous improvements as I go along.
Your post is timely for me as I am just producing a mold in pink foam. This I will have to sheet with some hard stuff inside as the mold would otherwise break easily.
What could I use to harden the inner shell of the crisp, but brittle pink foam? You can see a simulated run version of my foam mold milled in CNC from a friend (orange below).
ID:	859745   Click image for larger version
ID:	859746   Click image for larger version
ID:	859747   Click image for larger version
ID:	859748   Click image for larger version
analucius is offline
Old 01-24-2008, 03:24 PM
  #46
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When making molds directly from a CAD file to CNC I understand it is usual to use aluminum. If you try to finish the inside of a female mold made of foam it will be difficult to get a good match. You would have to be especialy careful arounf the parting line that you do not round it during finishing.
Old 01-26-2008, 12:47 PM
  #47
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi There,
I have always teated foam as a cheap, light, easy to sand filler that I cover with resin and mat when building a plug. That being said, dreadnaut is right. If you use CAD and CNC, the only way to preserve that kind of precision and detail is to cut it out of a medium that is durable enough to be molded. That material is almost always aluminum.
Old 01-26-2008, 06:11 PM
  #48
DocJones199
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Moving on with this turorial, PVA is now sprayed onto the plugs and the parting board. The PVA is an excellent barrier between the mold and the plug. I like to spray a coat, let it dry and then re-apply. Applying two coats of PVA can result in lost detail but that is not a concern for me with this project. An additional coat of PVA will ensure an easy release when I de-mold the plugs.
PVA is applied with my spray gun at about 60 psi and a distance of 8 to 12 inches. PVA is cheap and valuable at the same time.
For the molding process I need my air compressor and dump gun along with: tooling gelcoat, fiberglass resin and chopped mat, MEKP, rubber gloves, disposable brushes and a respirator or fume mask.
I begin by applying black tooling gelcoat with a dump gun at about 80 psi. I make sure to keep the gun close to my work because gelcoat makes a huge mess if it gets on something other than your project. I lay down a nice thick layer of gelcoat making sure to get good coverage around the base where the plug meets the board.
Old 01-27-2008, 04:08 PM
  #49
g_boxwood
g_boxwood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yesterday I got my first halves done (wing-tip floats of my 1/12th Canadair CL-215) and I'm pretty satisfied with the results:
They are some little nasty parts with lots of don'ts for a mold... so I'm happy they turned out as I expected.
Old 01-27-2008, 09:02 PM
  #50
Constrictor
My Feedback: (46)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: g_boxwood
Nice, so how will you join these halfs?
