Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Atlanta Fuselage Splash..
Reply
Old 10-03-2009, 11:35 AM
  #51
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta Fuselage Splash..
he could at least be doing a pattern arf build (assembly) while he's away from home and showing us that.
dhal22 is offline
Old 10-03-2009, 10:26 PM
  #52
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Roguedog
Hey Chuck. Thought I'd give this a bump again. Any progress?
I'm just dying to see pics of you laying one up.
Bryan
Good thread in need of a bump, I hope to be starting a project like this soon, and have been meaning to use some of these techniques on it (40 something inch e-yak for 4s)
dreadnaut is offline
Old 01-31-2010, 11:58 AM
  #53
Roguedog
Roguedog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Chuck,
I just can't stay away from this thread, I go back to it over and over .
It needed a bump.
Maybe this thread could be made a sticky for how to make a plug. It's an excellant tutor.
Bryan
Roguedog is offline
Old 02-03-2010, 09:06 AM
  #54
Atlanta 60
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bryan and hope your project I see in another thread works out for you!!
Atlanta 60 is offline
Old 03-01-2010, 05:35 PM
  #55
Roguedog
Roguedog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Atlanta 60
I'll start by posting a few pictures of the Airplane and then setting up the split line (parting line)...This is probably a little overkill...But I have more plans for this set-up and I'm hoping to re-use it if possible...I also wanted the fuse to "Stay Put"...It seems to be working out pretty well so far...Hopefully she'll be still through out the splash...
Chuck
Hey chuck.
I was curious as to how you attached the balsa to the fuse of your Atlanta. At some point you'll remove the added wood you used to cover the openings. Did you epoxy it in? Use Super glue? Also did you smooth over the surface atferward with alayer of Epoxy?
I went to start my mold but forgot about this very important part. I was going to tack glue it with Super Glue as I would lke it to come off easy but at the same time be sturdy enough for the molding process. Could you elaborate on how you went aboutpreparing the fuse?
Thanks again.
Bryan
Roguedog is offline
Old 03-01-2010, 06:33 PM
  #56
Atlanta 60
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah that's exactly what I did...Just tacked the balsa in place with super-glue then used bondo to fill in the opening with the balsa backing...It seemed to work pretty well as it held in place during the lay-up process and was cleanly removed afterwards...
Good luck with your project!!
Chuck
Old 05-25-2011, 11:11 AM
  #57
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chuck, how's this project coming along?
dhal22 is offline
