All Composite 1/7th P-40E Mould Build
#301
ON, CANADA
RE: All Composite 1/7th P-40E Mould Build
ORIGINAL: Luft-Gangster
Promised I would start, so here it goes
http://www.rcuniverse.com/forum/m_10441461/tm.htm
#302
ON, CANADA
Well, I've been relocated for just about 2 weeks now, so "the itch" is working its way to the surface again. I also have a new workbench that I "salvaged" from a junkpile. It's a great steel desk that had quite a few more bits and pieces that I didn't have room for, so I mixed and matched and came up with the stripped down configuration that you see here. It's sturdy, flat, level, and well re-inforced to make sure that it stays that way. I always frame on glass, so I won't be using it for that, but I was getting more than a little sore from working on my floor and coffee table. I hope to mount my roll of glass toward the wall so that I just pull on it and cut off what I need.
So here goes my first attempt at a canopy frame. For better or worse I'm trying a spray wax release. (too many requests for parts to spend a day waxing with carnauba paste each time - my preferred method)
My bulldog Bugsy says - "We've tried these sprays before and that's how we ended up at pure carnauba wax...."
#304
ON, CANADA
Release was exceptional. Although this part is not really a challenge in that respect as it can simply be peeled off the mould. As with the first pull on most tools, I found a couple of places that will require special attention to prevent underfill. If I was a rich man, I would spend the money on some consumables and draw vacuum on the next one.
I haven't put my hands on my dremel since the move, but once I find it, I'll trim this one up and spray some primer on it to see how much detail transferred.
#305
ON, CANADA
Well, I won't be using this one, but I think I learned what I needed to in order to make one worthy of putting back into the mould and forming the clear canopy around. I think we all get the idea.
#306
ON, CANADA
Today I decided to put together a vacuum source for our little canopy mould. It has a quick-disconnect to the compressed air source and is hooked directly to the vacuum port of the canopy mould.
This will allow me to pull and monitor vacuum on the mould with a little double sided tape around the perimeter of the flange (the smooth surface produced by the glass table top) and a piece of nylon sheet that I still need to salvage somewhere. (pool liner??)
Epoxy won't adhere to the nylon as the frame layup cures but is air tight.
The next layup schedule will be one layer of 2 oz/ft^2 cloth to fix the underfill spots where the heavier cloth didn't get into the corners and to eliminate the frayed edge when trimming with the cutoff wheel.
Once the frame has been trimmed and put back into the mould I will do a similar operation but with the clear canopy sheet across the mould face. Of course it will be heated to a malleable condition before it is sealed across the mould.
This will mould the clear canopy around the fibreglass frame.
Flip the switch and vacuum is pulled on the mould until it reaches an adjustable limit. Should small vacuum leaks develop during the cure, vacuum is re-applied automatically to maintain constant pull.
How many inches of mercury I can pull with this setup has yet to be determined and I'm not going to guess. Frankly I don't think it will take anywhere near 1 atmosphere (or 1 bar, or 28 inches of mercury, or 14.7 psi at sea level...etc)
I'd guess that there's roughly 1/2 ft^2 of mould face at even 10 psi would be like applying around 700 lbs evenly distributed directly on the mould surface.
I can't wait to hook up the compressor, open the valves, and throw the switch....
#307
Slow Low - Try a hot knife for trimming the canopy frame. Gives a cleaner edge than the dremmel. I use my dremmel for course cuts and the hot knife for fine. It cleans the edges up kind of like when you cut a nylon roap and use a small flame to seal the edges. The dremmel is like the knife, it leaves the strans loose.
Hot Knife = Soldering Iron with a exacto knife blade for the tip. Got mine at ACE Hardware. It came with both tips ( one for soldering and one for cutting ). Uses standard exacto knife blades.
#309
ON, CANADA
Wing Mould Day One
In order to mould the leading edge without a seam line, I need to stand the plug on the trailing edge. Easier than it sounds...
Rule #1 of Modelling - Waste not; want not.
This is the section of my junkpile desk that I did not have room for in my kitchen. The top is steel and is complete with T-slots. Best of all it's free!
The T-slots will let me bolt on some fixturing that can be removed or adjusted as necessary. If you can't see it yet - stay tuned, this thread is about to come to life again.
PostScript - you know, I probably drove by a thousand junk piles without a second glance - but a steel top of the right length to fit my wing mould pulled my truck to the side of the road without a second thought - crazy how your subconscious is always watching....
#311
ON, CANADA
I did some shopping this morning. I found a source for two interesting items only three doors down from my new apartment.
Half-round wooden knobs for registration between mould sections.
These were $0.22 each.
Coroplast Sheet - this is a very interesting material...
I will be using this material for parting planes. $1.39/sq/ft^2 is a little steep, but most of that charge was for the cutting service. It's just what they had ready to go; they thought they could custom cut me larger sections cheaper than what I picked up today. It has a nice smooth surface but there are undulations from the underlying internal structure. The ripple will provide some additional self-alignment in areas were a half-round registration key will not work.
The more interesting property of this material is it's strength to weight ratio in terms of longitudinal shear and compression. Will I be using longer lengths of this to cut ribs and a spar shear web from rather than ply and balsa? There's a very good chance.
#312
ON, CANADA
Not to jump around too much, but I also found a heat source for my canopy mould. $10 on sale from $50 - wow I think this thing should work great. I read a few reviews and they were all outstanding. (sometimes I'm a little leary about this particular brand name...)
I thought about making up an elaborate heating station, but frankly, I don't think I could've done any better for the cost.
#313
ON, CANADA
It's a fine line and I'm not sure which side this one comes down on....lol
At least I should be able to sit in my chair rather than standing bent over for hours while I make up this leading edge section.
(I never claimed to be a carpenter....)
#315
ON, CANADA
ORIGINAL: SCALECRAFT
Slow, What exactly are you trying to do in this composite wing configuration?
Steve
Steve
Remember Steve - Do or do not; there is no try. lol
#316
ON, CANADA
THIS IS NOT ADVERTISING, BUT IF YOU ARE READING THIS THREAD YOU MAY WANT TO TAKE ADVANTAGE OF THIS FREE DVD OFFER.
Here is the description.
Freeman's latest DVD, entitled "Making Parts, Patterns, Tools, & Molds, Fourth Edition", features over 2.5 hours of instructional and product videos, making it one of the most comprehensive resources available - now available throughout the USA & Canada for free for a limited time.
Inside this Fourth Edition DVD, you'll learn about:
* Building Epoxy Laminate Molds (w/ fiberglass)
* Forming a Carbon Fiber Part (vacuum bagging)
* Glove Molding Systems
* Paste Laminating Systems
* Making Rigid Molds With Fast-Cast Urethanes
* Making Urethane Rubber Molds
* Simple & Complex Silicone Rubber Molds
* Surface Casting...and much more
Plus, you'll have access to future videos that will include vacuum infusion, fiberglass repair, and more.
...and here is the link
http://www.freemansupply.com/dvd/
if the link no longer works, please let me know and I'll remove this post, as I think that this is a limited time offer (I got mine sucka's...lol)
#318
ON, CANADA
...still had a couple copies of the plans kicking around! Yeah!!! Much rejoice rang out at the template work that had been saved...
#320
ON, CANADA
...more to come, but I had a couple of minutes and these are necessary steps, so....
#1 - Ensure parting board is clean.
#2 - Wax on, wax off. 3X Carnauba paste (small, small circles)
#323
ON, CANADA
Dime-in-clay corner fillets will form upper, outer radiused edge of mould face once all white board formers have been removed later.
The parting plane along the trailing edge of the flap bay has turned out quite well and has been carefully positioned to fall precisely at half thickness. This will give the best case scenario for trimming along the mould edges prior to joining.
This clay work isn't finished yet. Stay tuned, there's still plenty of work to do before we paint on that silicon carbide tooling coat.
#325
My Feedback: (13)
Hi Slow
Looks good in the board. I found a pic of one of our 54" span composite corsair wings we made in 1991. Molds are still in good shape.
Just for the sake of info, this wing was laid up with 2 X 5.75 of plain weave "E" glass. it comes out of the mold around 1lb. It was a bit over kill and since has been modified with less wood framing and modified composite lay up.
The white section are plastic that creates a low spot to put fabric on that section. After thought. Our Hurricane is all composite and looks fabric.
The first spar needed to be ground out a little to allow the retracts (Rhomairs rotating) strut to seat correctly. Your model may not need this. It looks like the retract frame sits high.
Your lay up looks challenging/ time consuming due to the high prefabrication with those wells and ribs! I'm so out of patience these days.
Nice.
Steve
Nice.
Steve
