Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
All Composite 1/7th P-40E Mould Build
Reply
Old 06-14-2011, 07:43 PM
  #351
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: All Composite 1/7th P-40E Mould Build
The lowest cost solution seemed to be a hose repair kit. It cost me just under $5 for both the male and female brass fittings. I now have a couple of spare 1/2" gear clamps in the top drawer of my tool chest.
I've positioned the hose hookups on the rear face of the mould section so that the potential exists to hook the upper and lower sections together in a series configuration during final assembly with two small lengths of hose.
Normally I would wait an additional 24 hrs to demould the joined wing assembly. With heat to aid in reducing cure times and improving wing rigidity, I'm hoping to take a mould cycle from a tiresome 3 day operation to an easy 2 days per wing.
Slow Low is offline
Old 06-15-2011, 08:23 AM
  #352
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the first places to wear on a multi-piece mould like this, is the edge along which you trim semi-green parts just prior to joining. As a result, it's a very slow and tedious process to try and freehand.
This aluminum insert in the mould face will help to provide a nice durable trimming edge face. Notice the external grooving to aid in bonding with the tool surface coat.
It will also form an overflow channel to give excess resin during joining a place to go.
It might also provide a calibrated groove in which a custom trimming blade jig might ride...
Here's a source link (for future reference, 36" weighed in at 205 g)
http://store.workshopsupply.com/cata...ck-p-2954.html
...and here's the idea...
Slow Low is offline
Old 06-16-2011, 03:41 PM
  #353
I-fly-any-and-all
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ingenious! i'm eager to see your next video tutorial on youtube
I-fly-any-and-all is offline
Old 06-18-2011, 01:31 PM
  #354
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, first of all - thank you for your patience - I know that this takes forever, and now I've gone and switched things all around on you....
We still have the semi-spherical registration keys - but there are fewer of them. Fewer means less effort in keeping them clean and free from build-up. In an effort to maximize their effect however, they are placed at the extremes of the mould sections.
We still have the 1/4"-20 thread inserts for joining. There are a couple new ones. You can also see that I've countersunk the two on the end faces so that they will not interfere with removing the leading edge section.
The new bits are the extruded aluminum T-slot ways. I've filled them with clay, and then screwed them down to the parting board.
They will provide a nice flat, and wear-resistant face to trim against.
They will also act as an overflow channel during assembly.
But mostly, they give me the option of speeding things up considerably if needed at some time down the road. By vacuum sealing across the flange face and controlling resin flow into each of the nine overflow channels, while drawing vaccum from the underside through the gear bays it will be possible to infuse parts rather quickly.
I left the conduit for the heating circuit on top just for the sake of the picture: of course it will be embedded in the layup.
Slow Low is offline
Old 06-21-2011, 12:45 PM
  #355
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These bright white LED's will provide some light in the cavities where the control rods will extend past the trailing edge during final assembly.
(...because I'll be sure to be an old grey man with bad eyes by the time this thing's done!!)
How do you like my scale bullet holes in the wing skins in this first close up shot!?
Slow Low is offline
Old 06-21-2011, 12:47 PM
  #356
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slow Low is offline
Old 06-22-2011, 05:05 PM
  #357
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright, it's been 8 weeks setting up the first section of the wing mould. But it's good news / good news: I'll be starting the layup this evening / the next sections will be much quicker.
I've added some artwork that will be cast into the end faces of the mould (just for a little fun) and I've also updated the tool ID tag.
Stay tuned, there'll be ongoing pics, and so without further adieu...
Slow Low is offline
Old 06-23-2011, 03:05 PM
  #358
I-fly-any-and-all
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm anxious to see the resin being laid down!
Old 06-24-2011, 02:50 AM
  #359
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slow Low is offline
Old 06-24-2011, 03:58 AM
  #360
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's the first coat of tool coat applied, with particular attention to over hangs. Generally I mix up about 100 grams and put it into tight corners like where the part meets the parting board first while it still flows like no tomorrow. Once it starts to get a little thicker I move onto vertical walls, overhangs and the like.
I'll let this set up for an hour or two, and then I'll give it a second coat of tooling epoxy. I'm shooting for about 1/16" thick and complete coverage.
Haha - my tool ID tag fell off, but both bulldog tags stayed put - can't win for losing. I'll stick the tool ID tag on later I guess.
Slow Low is offline
Old 06-24-2011, 04:39 AM
  #361
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe this will be of use to someone else too.
File Type: pdf
Slow Low is offline
Old 06-24-2011, 06:57 AM
  #362
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2 of 2 coats applied tooling epoxy
File Type: pdf
Slow Low is offline
Old 06-24-2011, 08:23 AM
  #363
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is very light cloth. Mostly it's scraps of 1/2 and 3/4 oz/^yd
that I've set aside when covering other models in the past. I haven't laid any epoxy on it yet, just put it down on the tacky surface coat.
This is what you won't see a lot of others doing: they should.
I've placed it into all of the tight corners. What you do not want are air bubbles and voids. A heavier cloth will show through the tool coat over time and the surface veil will not stay in the tight corners.
Slow Low is offline
Old 06-24-2011, 09:15 AM
  #364
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've wet out the light cloth ensuring that it's into all the tight spots.
OK - I've now been working for 8hrs straight (can you say morphine) and I'm just about to start putting down surface veil. I hope you can see that this is something for which you need to set aside a couple of very long days and nights. Once you start, you don't want to stop or you'll need to sand the entire thing before continuing. (it never works out...)
Slow Low is offline
Old 06-24-2011, 09:47 AM
  #365
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This would be a typical first cloth layer. This is continuous strand surface veil or mat. It will stop the heavier weaves yet to come from showing through your surface coat over time. No need to apply it to the flanges: just the part.
You may be tempted to use a chopped strand mat, but the binder in it will react negatively with epoxy resins.
I will now wet this out with laminating resin.
Aeropoxy 2032 with a 30 minute hardener.
Slow Low is offline
Old 06-24-2011, 03:35 PM
  #366
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I double dog dare someone to try this on their own! lol
1st layer of 9 oz/yd^2 almost 15 hours into things - I haven't stopped for a coffee yet....
Slow Low is offline
Old 06-24-2011, 04:01 PM
  #367
I-fly-any-and-all
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ah I see you are having fun and making progress
nice work
Old 06-24-2011, 06:03 PM
  #368
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So now it's just 7 more layers....still haven't managed to eat...as soon as I finish at one end, it's time to start at the other again...
Slow Low is offline
Old 06-24-2011, 08:35 PM
  #369
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Slow Low
Now you did it. You got me off my *****. I got the composite bug again. Took 20 years but............
100% scale drawings off internet, got kid to enlarge them. Full composite 90mm edf. Tried not to look, but alas.
steve
SCALECRAFT is offline
Old 06-25-2011, 04:44 PM
  #370
Luft-Gangster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
F9F ???
Luft-Gangster is online now
Old 06-25-2011, 07:16 PM
  #371
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Luft-Gangster
F9F ???
F-104G
Steve
Old 06-26-2011, 12:33 PM
  #372
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, everything seems to have turned out quite well. The only thing that I'm not overly happy with is the sealer on my wooden registration keys didn't handle the job. Next time I'll use some Kermit the frog eyes from the craft store probably. This time, I'll use the back up plan around the perimeter.
Anyway, here are some early shots. I still have a lot of clay to clean etc., but hey, pictures are cool on a Sunday afternoon too...I'll have more to say later, but I need a coffee.
Slow Low is offline
Old 06-30-2011, 12:17 PM
  #373
kristijan-k
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice work !
Allways liked P-40E, very cool plane design.
Man, I really feel your pain, mold making is very nervbraking and time consuming.. [:'(]
I can relate, recently I done something similar, and also did not sleep about few days;
http://www.rcgroups.com/forums/showt...252959&page=10
Looking forward to see your molds finished, and first composite 1/7th P-40E completed.
Regards,
Kristijan Kljucaric
kristijan-k is offline
Old 06-30-2011, 06:20 PM
  #374
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry for the slow reply guys, but after a marathon layup, I need a few days to myself on the couch. lol At any rate, that's the first section done. It looks good, but it smells like money! lol
Hey Steve - now that I know you've got a bank account bigger than that plug you're working on, your only saving grace would be driving an old pickup, or drinking 18 year old single malt while your buddies drink beer by the pitcher - if you drive a Benz I hope your resin separates on you ;D
Kristijan - My hat is off to you sir: NICE WORK. (you europeans are always making us new world men look bad over here) Thank you for the link: it also led to a few others. You get an official Two Bulldog badge for patience and determination above and beyond humane limits.
ID:	1629954   Click image for larger version
Slow Low is offline
Old 07-04-2011, 08:40 AM
  #375
Slow Low
Slow Low's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alright, I've had a nice little rest so I thought I should document some things here while I've got a moment.
Since making the fuse mould in 16pcs that each contained 13 layer laminations, at about 3 hours each, I decided that I needed to explore methods for not only speeding things up, but also reducing material costs. As a home hobbiest, you know that the further you can stretch a buck, the better. And afterall, we're building model airplanes here....
The first thought, as silly as it sounds was to go to a bigger brush. Well, that means mixing larger batches, which means a new scale. It also results in using about twice as much resin, but that's another story.
After some thought about rigidity of the tool, I came to the conclusion that what was needed, was much the same thing that's needed in a wing; a spar to take the bending moment produced along the length of the wing, and something to resist twist.
In the end, by using an integral fibreglass outer shear flange around the tool perimeter, and also incorporating the aluminum extrusions at acute angles in the tool face, I was able to cut the 13 layers down to 6 in the tool face and only 4 around the vertical perimeter shear flange.
More substantially, in terms of cost, I went from 2 gallons of laminating resin down to under one. In ballpark figures that's about a 60% savings in the material cost of this tool. The labour savings, although I will not quantify it here because it would require me to assign some certain degree of value to my skill level, was priceless to a guy who couldn't feel his legs after laying down each layer.
What does General Bugsy think of our new toy?
Slow Low is offline
Reply
Display Modes
