All Composite 1/7th P-40E Mould Build
#477
ON, CANADA
RE: All Composite 1/7th P-40E Mould Build
Upper Wing Skin #1
I wonder if I could introduce a two part pourable closed cell urethane foam into the brass fittings and get it to react slowly enough to avoid voids...maybe at a 2lb/ft^3 density. I've tried before with limited success, but first we'll try a simpler approach to see where we stand.
#478
My Feedback: (13)
Slow the urethane foam will create an extremely strong wing. Like a a park bench really. But it will be too heavy for this application once you have a completed air frame.
Unless you want a really strong static model.
We did that in 1991 with our 63" span all composite Hawker Hurricane just to see what happens. It was heavy. Used it for extra seating in the lunch room.
Steve
Steve
#479
ON, CANADA
Thanks Steve,
I was thinking about filling my cavity with water and then emptying it into a graduated cylinder in order to get an accurate estimate in volume. The flap bay geometry should provide a whole bunch of strength in the root area so perhaps creating a cavity for foam just in the area of the ailerons would be enough to prevent twist.
Do you recall what kind of density you were targeting ? For what it's worth, I don't remember anything from the 90's....
#480
My Feedback: (13)
Slow.
You are welcome to try the foam. Not the tell you your business, but
Since the 90's we have made around 15 asst all composite warbirds. What has always worked exactly as it was designed to do, was the hollow composite wing with balsa and ply framing. Similar to the construction of the real aircraft. You can use carbon or kevlar reinforcements, but not necessary. this method never failed in flight, even to this day with our current projects. My F-104 in EDF will have the same type of wing configuration. Even my turbine F-104 version.
Your volume calculation not work well, because the two part urethane foams expand far beyond the liquid volume. The other problem with the urethane resin is that it will be expanding for quite some time after its out of the mold. It could bulge the wing causing airfoil changes and distorting the fit of the wing to the fuse, ect.
To avoid wing twist or folding, I would use the configuration shown in the pictures. Basically, the key is the spar glued to the ribs along with the glass skins kept apart by the framing. Nothing new. Remember Monocote wings?? They worked, glass wings are way better. But why doesn't everyone make glass wings?? They tried, but make them too heavy.
You have invested a lot of EVERYTHING in your project. Your mold is done far beyond the stresses it will see, which is not a problem. But over engineered.
If I may suggest,......
Your lay ups are too wet. That equals weight. Also, more epoxy is not good for the glass. It weakens the structure. Your fuse with the camouflage colors in the epoxy was a nice layup challenge , but not a good fuse for flight. Next one, clean light lay up then paint it.
You can be way lighter and stronger with a 4oz and a 6oz placed correctly with proper amount of epoxy. Also your mold configuration as you have made it, is a difficult lay up. As you may have notice by now, you have too many corners/"humps" in your mold. This creates the need for patches and fillers. Weight.
I would lay up my wing in either 2- 6oz, or a 4oz and 6oz one piece layup. Design a frame and your done. The flap details I would use a very light glass just to minimize the need for filler.
I guess once your P-40 is properly Cg'ed, it will be in the 8-10lbs range. I have the Topflite P-40 your model is off of. I also had the red box version of the Topflite P-40. it took a ton of ballast in the nose once the gear were rotated back. Don't remember the finished weight though.
The problem is to get an air frame out of the molds that lands safely.
Again, great effort, but don't over engineer. It's just weight.
As one of the best Structural engineers once said, " The difference between a good engineer and a bad engineer is the good one does not over engineer for the design"
Again, what easily works for me and my little group of composite flying friends may not work for you, but it could be a short cut to a bad ***** flying composite for you.
Steve
Steve
#481
ON, CANADA
Thanks Steve - you hit the nail on the head - I'm trying to eliminate all of that wood cutting
550 grams or 19.4 ounces or 1.2 lbs - room for improvement
#482
My Feedback: (13)
The Corsair wing may be a bit much for an example.
The configuration more similar to your wing would be our 109, except for the gear. 1/4" balsa mostly except for LG plate, that's 3/16"5 ply.
Very few pieces in the wing frame. Flies very well and forgiving on landing. Take offs are still typical 109, hard.
Steve
Steve
#485
ON, CANADA
These leading edges should be nice and light.
All they have to do is deflect air over the spar.
#487
ON, CANADA
ON, CANADA
My Feedback: (13)
Nice work Slow. I would have given the wheel well more clearance. They tend to hang up on the rotating type. Maybe a smaller tire?? My 2centss.
Keep it light, the P-40 is a nose heavy bird in the RC model configuration. Especially when the gear rotate back.
Keep it under 9lbs and keep up the airspeed when landing. At first ......
Good luck
Steve
Good luck
Steve
#491
ON, CANADA
thanks Steve - that's a 4" wheel for a scale appearance, but the initial plan called for 3" - I've got them around here too
the draft on the well and the radiused wall on the tire may be enough to guide things into place - if not I'll just use 3" like others I've seen
#493
hey are you still making parts for the top flite p-40?
I now have almost finished my associates in mechanical engineering and design and currently work as a machinist programming cnc mills, setting up stock and tooling, operating, making plastic injection molds. that kind of thing....
