Vacuum set up with Air tank or Compressor
I wanting to try some vacuum bagging and saw where some use an air compressor or even an air holding tank.
Can I get some web sites or ideas how to make this work? I really don't want to spend the money for all the other stuff since I have both of these units. I pretty much have the rest of the info and supplies...just need a good suction device.
I've seen vacuum generators on http://www.fiberglast.com under Vacuum Bagging Equipment. I bought a vacuum pump thru www.grainger.com for cheaper than the other fiberglass online sites. Hope this helps....
Dustin
Dustin
If you already have an air compressor, go with the vacuum generator for about $100. I'd rather go with a new/slightly used vacuum pump on Ebay for about the same price though. That's what I did.
I guess I am aasking more about how do I convert my air compressor or air tank to use it for bagging.
Maybe the refriderator cpmpressor is the cheapestt set up I may be able to find. I'm just tinkering and looking at one for doing dome model Glass boats.
Thanks for any help.
