Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Carbon Fiber Sheet Help
Reply
Old 06-02-2009, 04:23 AM
Magne
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Carbon Fiber Sheet Help
Quote:
it sounds like you are building a lip around the perimeter of the bulkhead in the fuse correct? won't the fillet that is formed on each side of the former when attaching it to the fuse serve a similar purpose?
Yes, in a way I am suggesting building a "lip" around the perimeter of the spar/bulkhead, equivalent to the flange of an I-beam.  The plywood/carbon plate would be equivalent to the shear web of the I-beam.  This lip is however not limited to the area inside the fuselage, but continues the full length of the spar.  The lip is made of carbon fibers, and is therefore very strong.  A glue joint (fillet) is not very strong in comparison.
Magne
Magne is offline
Old 06-03-2009, 07:14 PM
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ahh, I see what you mean, Magne. But if you create a lip running out along the plug in spar, won't that make it difficult to create a nice box for it to slide into? I think my plan is to laminate 2 sheets of 1/8 aircraft (5-ply) ply together with fabric in between and on each exterior under pressure. Then cut out my part shape from that. I did get some nice 1/8 ply parts cut from AK Models (thanks flyintexan for the lead) but I think going with the layup first then cutting will work better.
smchale is offline
Old 04-07-2011, 02:34 AM
leilijia
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Sean :
       I here noticed you are looking for Carbon Fiber sheet for water ject Project .
      My name is Lei from CHN Carbon Fiber Technology Co.,Ltd ,  Located in yixing city , Jiangsu Province , CHINA .
    We are a Leading Manufacturer of carbon Fiber Products -sheet , tube , rod and export to US , Denmark , Spain , Turkey , Poland ..
    Currently our Standard Sized CF Sheet is 500mm*600mm , Surface is smoothly finished , Prices as follows :
     CF Sheet             Size                           Thick               Unit Price
                             500mm*600mm           0.5mm           $31.2
                             500mm*600mm            1mm             $55.7
                             500mm*600mm          1.5mm            $79.2
                             500mm*600mm             2mm             $102
Based on big QTY ,  Discount is offered to customers .
  IF you are still looking for best Source , You can make a Comparion of my Prices with US Local Sources 's .
 Welcome if you have Inquiry
          Lei
      Email :  leilijia1987@163.com
      www.chn-cf.com
       CHINA
leilijia is offline
Reply
Display Modes
