Fiberglass fuse dent repair.
I have an old ducted fan F-104 that I am making a winter project out of. The fuse has a coat of primer that has cracked off in numerous places. I am going to strip it with Citristrip, which I read works great for this. There are two areas where the fiberglass is slightly bowed (but not broken) from something pushing on it for a long time. How can I pull these "dents?" Can I use a heat gun and try to work/push them out? One is the size of a baseball, pushed in about 1/2 inch. The other is a warped piece between two panels. Thanks. -Chris
RE: Fiberglass fuse dent repair.
It is a JD Enterprises F-104. Epoxy. It is in good condition, I am actually striping the primer on it a I type. Still flexible, just like new. Not brittle at all.
Here are some shots of the damage. First is the dent. I can pop it out by hand, but it returns when I let go. I figure if worse comes to worst I can glue a sheet of wood from behind it to keep the shape. That is assuming heat won't work. Second is the twisted piece that separates the gun hatch from the front gear opening. I could probably straighten it if I glued the hatch on permanently. but I would really like to hinge it and hide charge jacks and retract valves behind it. Ideas?
ORIGINAL: Sessholvlaru
MattK
BTW- I see you live in West Caldwell. Where do you fly?
Thanks MTK, I figured heat was the route. I fly in Moonachie at the Hackensack Valley Flyers. This thing will never get out of that field when it is done though, will probably fly it at Floyd Bennett field. What field do you call home?
