For Speedracer
Hey Speed/All,
I want to get a vacuum bagging setup, I know speed has said to me before he has a system that I can put together cheap. Speed do you have that information, I have tried to PM you not been out to the field much lately. Anybody have any suggestions. James |
RE: For Speedracer
I'm not SRT but a vac system is fairly easy to build using an old fridge compressor and a vacuum limit switch. That's how I did mine.
Since then I picked up an ACP unit that works very well for wings. However it only pulls 8# and isn't quite strong enough for my taste when doing straight carbon layups. That said it's a great product and they make one with a little higher rating that would do everything. Mine is just a little smaller and a great deal when I bought it.;) |
RE: For Speedracer
James, I sent a reply with a bill of materials via PM and to your email. Not sure why you didn't get them but the best thing is for you to give me a call and we can make plans to get together and I can show you my setup and give you some insights on bagging wings or whatever else you may want to do.
509-4459 |
RE: For Speedracer
1 Attachment(s)
However it only pulls 8#?
Not sure what pump system you will end up with but if you are vacuum debulking sheeted styrofoam cores you do not want to be anything much over about 5" hg or you will most likely crush your core. Now if you are performing a solid laminate, a laminate with structural PVC core, or a laminate with honeycomb core then you really want your vacuum at a minimum of around 22" hg and the closer you get to 29" hg the better. Here is what happens with just a tad too much vacuum on a sheeted styrofoam wing panel. Bob |
RE: For Speedracer
Thanks Speed, I will call you tomorrow night (friday)
RE: For Speedracer
Sensi, I do quite a few Q500 wings a year as well as bulk layups of carbon. I have to turn the fridge pump down quite a bit or it will crush the core as you mentioned. The ACP pump I have is perfect for foam jobs but not quite up to task for bagging wood core tail sections.;)
RE: For Speedracer
ORIGINAL: vicman Sensi, I do quite a few Q500 wings a year as well as bulk layups of carbon. I have to turn the fridge pump down quite a bit or it will crush the core as you mentioned. The ACP pump I have is perfect for foam jobs but not quite up to task for bagging wood core tail sections.;) Bob |
RE: For Speedracer
It depends on the foam. I bag XPS foam wings at 25" Hg
RE: For Speedracer
ORIGINAL: wyowindworks It depends on the foam. I bag XPS foam wings at 25'' Hg Bob |
RE: For Speedracer
ORIGINAL: wyowindworks It depends on the foam. I bag XPS foam wings at 25" Hg |
RE: For Speedracer
I'm getting ready to bag the skins onto my Dalotel wings. Will most likely happen late next week. If there is interest, I will publish pictures here of the sep by step process I use. Matt, yes I did sell the other Laser. It's been finished and flown.
RE: For Speedracer
Please do It would be nice to see what other people are doing to bag wings and what your bagging system is and set up is great help also.
Darren |
RE: For Speedracer
I would enjoy seeing how you bag a wing and your vac system!
Don |
RE: For Speedracer
1 Attachment(s)
I finally found time to get some wing panels sheeted. The first thing to do is tape the sheets together. I edge true them by hanging the sheets about 1/4" off the end of my bench then laying an aluminum strait edge on top of the balsa sheeting. I then sand the sheeting to the strait edge. After the sheets are tapped together and cut to size I did the cutouts for the retact and servo mount. The sheets get wetted out with epoxy, just enough to get them wet, extra epoxy will not add strength. I added some light glass cloth to sperad out the stress riser created at the end of the wing tube. The sheeting is applied to the core and placed into the shucks. The shucks and cores go into the bag. The bag can be made of plactic tarp material and sealed with latex caulking. Vacuum is pulled to about 7 inches. This will set for no less then 3 days. The theory is that the wood contains some moisture. The bagging process removes the moisture or at least ballances the moisture between the seperate balsa sheets. This will reduce the possibility of warpage later. The vacuum will also draw the epoxy into the seams of the wood sheeting.
RE: For Speedracer
1 Attachment(s)
More pics
RE: For Speedracer
1 Attachment(s)
End of pictures
RE: For Speedracer
where did you get the vacuum switch
RE: For Speedracer
are you guys using the hk pump or turbine fuel pump bought the hk system runs quits runs quits though it was the controller hooked to batt still the same thing
