RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Composites Fabrication And Repair (http://www.rcuniverse.com/forum/composites-fabrication-repair-97/)
-   -   Composite Q500 wing Material? (http://www.rcuniverse.com/forum/composites-fabrication-repair-97/1448928-composite-q500-wing-material.html)
Randy Etken 01-20-2004 01:10 PM
Iam about to make a Q500 wing, vacumed baged in a female mold. What size fiber glass do you use on the outer and inter layer between the balsa? And what size balsa would you use.
Thanks Randy
daven 01-20-2004 02:20 PM
RE: Composite Q500 wing Material?
Randy,
I just talked to Terrance (Neme-Q designer/manufacturer) about this in Phoenix over the weekend. He said that he use to use 1.4 oz cloth on the outside, 1/16" balsa in the middle, and 1.4 oz cloth on the inside. He has since reduced the thickness of the inside cloth to 3/4 oz and hasn't had a problem.
Did Dana finish your molds?
