Control Lines For all you fly-by-wire fanatics!
Flapless stunter v2.0
Reply
Old 02-09-2011, 12:36 PM
cutaway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flapless stunter v2.0
Even though its cosmetically very different, [link=http://www.rcuniverse.com/forum/m_6837644/anchors_6837644/mpage_1/key_/anchor/tm.htm#6837644]this plane is an evolution of another built a few years ago[/link]
v1.0 turned out to be a bit on the hunty side but was otherwise very capable, so I lengthened the tail moment to 16" wing TE-stab hinge line. The wing area has been upped to around 560 square inches and keeps the same NACA 0023 airfoil used in the original.
I'm hoping the flat tips with toe-in at the wingtips will assist in tracking straight and smooth through hard turns. Stab and elevator area are increased a tad in anticipation of perhaps adding flaps on v3.0
All up I expect the weight of this one to be about 12oz heavier than the original putting it in the 45oz range. I plan on putting a .40-.45 size engine in it this time.
The covering is a mix of silk, silkspan and Skyloft. The wing is in Skyloft, the fuse/rudder silkspan and stab/elevator in silk. The whole thing was done with Sig Supercoat so far, since I was out of Nitrate. Hopefully its strong enough to not get twisted into a pretzel in the sun by the Supercoat.
cutaway is offline
Old 02-09-2011, 12:50 PM
BtnFlyGuy
BtnFlyGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Flapless stunter v2.0
Looks pretty good. Might I suggest tip plates to help overcome the wingtip vortices inherent in a blunt tip design?
BtnFlyGuy is offline
Old 02-09-2011, 12:54 PM
cutaway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tip plates were on the list of field experiments to try with this one. I made sure the underlying structure was beefy enough to retrofit them when it was being framed up.
cutaway is offline
Old 02-09-2011, 12:57 PM
BtnFlyGuy
BtnFlyGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Best to you? Where are you from? I'm in New England and suffer from a lack of flying partners. Right now I'd be flying something with skis though.
Old 02-10-2011, 06:33 AM
cutaway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BtnFlyGuy
Originally northern NY near the NY/VT/MA triple border point east of Albany. I fled the north east 30 years ago for CA, and now I've been in FL for over 20 years.
cutaway is offline
Old 05-05-2011, 05:46 PM
Recycled Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cutaway
......... v1.0 turned out to be a bit on the hunty side but was otherwise very capable ..............
Have you tried out about 0.5 degree of downthrust yet? You may be able to simply hold the engine in that attitude and then tighten the mounting bolts up to convince it to stay there, worth a shot I think.
Cheers.
Recycled  Flyer is offline
Old 05-05-2011, 07:22 PM
cutaway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think V1 was a bit tailheavy initially, and that combined with a 2" bellcrank contributed to the huntiness. When I fitted a heavier ST G34 and rebalanced it, and replaced the 2" with a 3" after a crash, it started to groove as well as it could with the shortish tail moment.
cutaway is offline
Contact Us Archive Advertising Cookie Policy
