Control Lines For all you fly-by-wire fanatics!
Q's Soviet Mk17 diesel on a profile
Reply
Old 05-04-2011, 04:25 PM
cutaway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Q's Soviet Mk17 diesel on a profile
I was impressed enough with the .09 Mk17 on the bench to shrink one of my .35 size stunter designs down around it, but not having run any of these in the air, I have some Q's that will affect the design of the nose and tank I construct for it.
1) Is it sensitive one way or the other to pickup centerline, like the Fox .35's are?
2) Does it have enough suction to operate successfully with uniflow plumbing? On the bench I just ran it conventional venting.
cutaway is offline
Old 05-05-2011, 05:33 PM
Recycled Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Q's Soviet Mk17 diesel on a profile
ORIGINAL: cutaway
1) No, it is not sensitive one way or the other because it is a radially ported and symmetrical engine unlike the Fox that has the massive transfer port only on one side and is bias.
2) Yes it will have enough suction to operate successfully with uniflow plumbing but if you have any lingering doubts I believe that these engines came with two venturi inserts so simply use the smallest one and progress from there.
Irecommend side mounting the engine as it will be far easier to 'clear the sinuses' if flooded and you can adjust the compression screw far easier.
Good Luck!
Recycled  Flyer is offline
