Control Lines For all you fly-by-wire fanatics!
C/L engines for sale
Reply
Old 01-15-2012, 08:57 AM
paulgibeault
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default C/L engines for sale
Hi Guys, for some reason I'm not able to use the for sale area.
If you need further info or photos please contact me: pgibeault@shaw.ca
Cheers, Paul
Fox .35 Stunt (early silver case), w/ O.S. NVA,VGC $50
GMA Fox .35 Stunt ABC w/ Adamisin Muffler , GC $125
GMA Fox .35 Stunt w/ S/T NVA GC $125
4/ Fox .35 stunt (early silver case), VGC Lou Crane modified, unrun. $100
32/ Fox 35 stunt, modified by Lou Crane, all instructions, run in only,VGC $125
32A/ - Fox 35 stunt, T. Dixon Stage 3, Windy muffler, 6-32 lug holes,VGC $125
Fox 36 R.X. looks unrun + 3 spare piston rings. $40
Fox 15 ABC Experimental Prototype, c/w carb, muffler & venturi $200
10/ OT schneurle cub HC, NIB, decals, instr, $320
11/ OT cub Mk 1, VGC (but needle is missing) $350
13/ OT cub w muffler, VGC, almost looks unrun $300
12/ OT Mk 4, MHC, NIB, inst, spare NVA $320
14/ OT Mk 3, orig box, faded logo looks unrun.$300
17/ OT Mk 3. rebuilt by JO. Oct 90 unrun since. muffler.spare RC NVA. worn lugs, good condition. 2 spare NVA $330
9/ OT Major, HC liner, muffler, NIB $300
- (3) OT 15 Needle Valve Assembly $20 ea
18/ Super Tigre .46, New, modified by Lou Crane, unrun. $200
21/ ST .46 orig. box and instructions, modified by Jim Greenaway, unrun.$200
22/ ST .46 w/ muffler orig. box and instructions, VGC $150
25/ ST G15FI Goodyear NIB $175
27/ Rivers Silver Arrow Mk 2, 3.5 NIB, instructions. $200
31/ PAW 09 Mk 1 CT NIB, + 2 spare NVA. $125
33/ OS .40 FPS, NIB, modified by Randy Smith, std. muffler $175
34/ OS .35 stunt, orig box, instructions, std muffler, VGC $90
40/ OS .35S modified by George Aldrich, VG condition, factory muffler $175
42/ OS 20S. VGC. factory muffler. $70
OS 40 FP R/C w/muffler VGC $50
OS 40 LA w/ tongue muffler GC $55
Brodak 40 AAC Stunt w/ tongue muffler VGC $95
3/ Veco .29 R Boxed, instruction VGC
37/ McCoy .35 red head, New.
39/ ED racer, 2.5cc reasonably good cond. $75
41/ Amco 35 BB, reasonably good cond. $60
35/ Frog .349, orig box & instruct, muffler, flywheel and water jacket,VGC $75
36/ AM 10, no tank, VGC $50
Norvel BigMig .061 w/ muffler VGC $40
Norvel BigMig .074 R/C.w/ muffler NIB $60
Norvel speed plugs $7 each (5 available)
MDS 40 R/C w/ muffler NIB $50
Taiphoon 2.5 Glow Combat NIB $50
C.S. NIB .061 F/F w/ 3 extra glow heads $100
C.S. NIB .049 C/L Speed c/w 2 pipes (rec'd while at the C.S. factory) $150
Nelson 15 F.I.R.E. Longstack ABC w/ spinner, 12mm crank, VGC $200
K&B 35 Plain Bearing. GC (one fin missing on backside) $45
K&B 40 R/C GC $40
Cox K/K TD .049 NIB $100
Cox K/KTD 049 L/H Protospeed w/Chrome crank, Hi-comp hd & L/H prop $100
Cox TD .049 Original New in Jewel Case $85
Cox TD .049 New $70
Cox Early TD VGC $50
Cox TD w/chrome crank, K/K NVA, KK pres. backplate $100
Cox TD w/chrome crank, K/K NVA, $85
Cox TD mounted on Cox Pan. Cyl & plug turned down to fit in pressure cowl, K/K fine thread remote NVA installed, Special Speed spinner ass'y, matching Fiberglass speed top $150
Cox TD .051 w/ extra F/F flood-off venturi $35
Cox TD Free Flight radial backplate mount $4
Cox R/C Bee .049 NIB + extra glowhead $50
Cox R/C Bee .049 New c/w ext glow plug, 6 X 4 prop, (2 available) $50each
Cox R/C .049 w/ Kavan Tank Extender, spring starter + extra glowhead $40
Cox/Estes Killer Bee .049 NIB $35each (2 available)
Cox Original parts Golden Bee + ext glowhead $55each (4 available)
Cox Original parts Golden Bee + ext glowhead (nearly new) $70 each (2 avail)
Cox Super Bee w/ spring stater + extra glowhead $35 (3 available)
Cox Babe Bee w/ spring starter + extra glowhead $20 (3 available)
Cox Babe Bee New in Yellow blister pak $65 (2 available)
Cox Babe Bee New in Striped Blue blister pak $50
Cox Black Widow New in Original Spider Box. $85 (2 available)
Cox 290 w/ spring starter + extra plug $7
Cox 290's (pkg of two) $5
Cox Globee Racing glowplugs $6 each (11 available)
Cox Globee Standard glowplugs $6 each ( 3 available)
Cox speed pan $7
Cox car heat sinks (pkg of two) $5
Cox Standard Glow Plugs: $4 each (quantity 100)
paulgibeault is offline
Old 01-15-2012, 01:06 PM
coriolan
coriolan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: C/L engines for sale
Paul, you should also put your list on RCG either in the C/L forum or the FS/W section:
http://www.rcgroups.com/control-line-63/
http://www.rcgroups.com/aircraft-fue...ries-fs-w-362/
Saw you fly at the VGMC in Richmond years ago when Chris Sacket was still flying there[8D]
coriolan is offline
Old 02-08-2012, 09:40 PM
paulgibeault
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the help. Just fairly new at using these internet web sites... Paul
Old 02-09-2012, 09:18 AM
Hossfly
Hossfly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: paulgibeault
IMO, eBay would be your best bet. OTOH your reserve prices may be a tad on the high side. eBay works best when the reserve is rather low and the shark's frenzey gets going in the last 5 minutes. I have sold, won, and lost a lot of items in the last 5 seconds.
I thought I knew a lot of engines however what is the OT you speak of. [:-] I own a number of Old Time Sparkers but they all have names like Arden, Anderson Spitfire, Super Cyclone, Madewell, Bantam, Thor, etc.
Good Luck.
Hossfly is offline
Old 02-09-2012, 11:09 AM
coriolan
coriolan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Hossfly
Good Luck.
"OT" stand for Oliver Tiger,mostly used im C/L team racing,combat and Free flight.
ID:	1725065   Click image for larger version
coriolan is offline
Old 02-09-2012, 11:38 PM
Hossfly
Hossfly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
''OT'' stand for Oliver Tiger,mostly used im C/L team racing,combat and Free flight.
Of Course. I take the Dunce Cap! The OTs are definitely a famous brand and here I forget it. Sad Sad on me.
Thanks for the update.
Hossfly is offline
Old 02-12-2012, 01:58 PM
clscale-RCU
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a lot of engines....Wow...
I have unloaded a bunch of my engines lately since I have recently converted over to electric power
I have sold engines thru these sources with good luck
www.rcuniverse.com
List your engine with a price and people make an offer, if you accept the engine is sold
Look for the classified section and post an individual ad for each item, don't combine items under one ad, even if they are the same type of engine, run a separate ad for each engine, makes thing easier to track.
Even if it's a CL engine it still might sell on RCuniverse
www.ebay.com
the other reply is correct set the reserve price correctly and as low you are willing to go and let the auction frenzy go
I have tried Stunthanger classifieds but found that RC universe and Ebay see more traffic. I was selling RC engines with Carb's.
Good luck!
Fred Cronenwett
clscale-RCU is offline
Old 02-14-2012, 05:32 AM
paulgibeault
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops! Sorry about that. OT stands for Oliver Tiger.
Old 02-15-2012, 08:31 AM
zedad71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,,
really selling off all your engines? or just extra,,,
are we still going to see you in Eugene?
zedad71 is offline
Old 03-22-2012, 01:49 PM
willfann
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
I am looking for some OS Max 40 H Stunt parts. I really need the muffler, prop washer and nut and venturis that fit. Buying a used one for parts is also an option.
Thank you.
William
willfann is offline
Contact Us Archive Advertising Cookie Policy
