Control Lines For all you fly-by-wire fanatics!
Simple Trainer for a .15?
Reply
Old 08-05-2012, 12:06 PM
Seamus OLeprosy
Seamus OLeprosy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Simple Trainer for a .15?
I have never managed to succesfully fly a control line model and dont want to head north without giving it another go.
I ordered a couple of these .15 2strokes from Hobby King for a R/C twin I will build over the winter.
What I was hopeing is that someone knows of a C/L trainer plan that I could download and put together quickly.
I have a forest of balsa so dont mind if its a solid wing design
Seamus OLeprosy is offline
Old 08-05-2012, 03:02 PM
greggles47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Simple Trainer for a .15?
Hi Seamus,
The Sabre is an old Oz trainer. Simple to build, rugged, and a good flier.
For a modern 15, like your AP the only change I'd recommend is to increase the span from 20" to 30". Also the fin has a tendency to break off on a roll over, so some support there will help.
Regards
Greg
File Type: pdf
greggles47 is offline
Old 08-05-2012, 09:56 PM
Seamus OLeprosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Greg
Old 08-06-2012, 04:53 PM
gcb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might also consider setting the wing incidence at zero.
George
gcb is offline
Old 08-06-2012, 11:39 PM
greggles47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well spotted George.
We in Sydney use the Sabre for a fun racing class, and taking the incidence out is but one of the allowable changes. Another is not using a flat bottom wing section. Most opt for either 2/3 to 1/3 or even symetrical.
These changes can be incorporated if Seamus wishes, and will make the model fly a little better at trainer speeds.
With the motor suggested I'd use 50' lines.
Regards
Greg
Old 08-07-2012, 06:31 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And unscrew the muffler stinger for a bit more power if you need it.
aspeed is offline
Old 08-07-2012, 06:48 AM
Seamus OLeprosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now you's starting to confuss me
Old 08-07-2012, 10:24 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The AP muffler is constrictive.  Opening up the outlet on it gives it a lot more power, I just unscrew the outlet, or take off the muffler if the field allows it. Only if you think you need the extra power. On a trainer you likely don't need the power for a while.  I already am preconfussed.
aspeed is offline
Old 08-09-2012, 08:38 AM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is one of my Guillows #2 trainers. It has hundreds of flights on it. Engine is a worn out McCoy 19 with 9 x 4 prop. In a fourstroke it gives 7 sec laps on 65 ft 015 lines. Not uniflow, so the last few laps are down to 6 sec; about 28 laps total.
Dimensions are; span 30 in, Chord 7 in to 5 1/2 at tip, fixed flap, wing 3/8 thick. 5 in from LE of wing to glowplug, 15.5 from LE of wing to elevator hinge line, stab span 13 in, stab 2 1/2in center with 2 in tips. Elevator 1 5/8 in center with 1 3/8 tips. CG 3/4 in back of wing LE. Fuselage 3/4 balsa, engine mount 3/4 in hardwood.
ID:	1790485   Click image for larger version
ID:	1790486   Click image for larger version
Jim Thomerson is offline
Old 08-09-2012, 11:36 AM
Seamus OLeprosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim is there a pdf plan?
Old 08-09-2012, 12:22 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not that I know of. It is simple enough you could draw your own plans. Generally, on an airplane like this, you just start measuring and cutting, no need for plans.
Old 08-09-2012, 12:49 PM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks pretty good.  Maybe a straight profile fuselage would be easier, but not much, and the landing gear wouldn't be as solid.  6 seconds a lap should be enough time to figure out how to fly it.  Don't forget the tip weight.
aspeed is offline
Old 08-09-2012, 02:54 PM
Patxipt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's one I built, flies nicely, even with a simple plank wing
More models on this page :
http://www.jpaeromodels.com/planosvu...iniciacion.htm
File Type: pdf
Patxipt is offline
Old 08-11-2012, 05:13 AM
Seamus OLeprosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Patxipt
Old 08-11-2012, 08:11 AM
paw080
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Jim Thomerson
Hi Jim, My Dad bought the precurser to that model, I believe it was simply called the
Trixter Trainer. It had a 28" wing span, and came with wire landing gear and a pair of turned
hardwood wheels. My Dad mounted an OS Max-1 .35 in it. It actually was a great flying model,
My Dad flew solo on his second flight. I flew it several times and managed to fly it inverted
from a wingover entry. That was rather bold(stupid..!) of me since it had the cumpulsory
2 ounce Rectank. My dad flew it on .015" X 60' lines. He gave the model to some kid at the
flying field(Hawthorne HS Calif) several months later, but kept the engine and installed it in
an AJ Firecat. My Dad probably flew the Trainer over 250 times.
I'm sure it would have flown much better with your McCoy .19, because it didn't glide very well
with Max-1 .35 in the nose. Thanks for jogging my memory with your pics and comments.
Tony
paw080 is offline
Old 08-11-2012, 01:22 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ideal way to learn to fly control line is to have a slow stable airplane to fly, and have an experienced flyer out in the circle with you. The experienced flier holds your hand for the take off and first couple of laps, until you get the feel of it. Then lets you take over until you start to get dizzy. The experienced flier takes back the handle, and lands the airplane while you lie on your back with the world spinning around. Subsequent flights you will become more skilled and less dizzy. Soon you will be able to take off, fly the tank out and land by yourself without getting dizzy.
Old 08-11-2012, 01:35 PM
Seamus OLeprosy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Woo woo woo Jim. Are you saying I have to hold hands with an old bloke, have a little dance and then we have a lie down in the long grass?
I'm sticking to R/C, even a buddy lead is 4ft long and no touching
Old 08-11-2012, 03:55 PM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Seamus OLeprosy
Well here is an option a dual handle
flyingagin is offline
Old 08-11-2012, 04:01 PM
greggles47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seamus,
That's hilarious!! I can't stop laughing.
Greg
Old 08-12-2012, 07:51 AM
gcb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After you learn to fly (by yourself) you will probably want to fly stunt or speed. Forget about team race or combat.
George
gcb is offline
Old 08-12-2012, 09:41 AM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seamus OLeprosy The picture of the double handle that Flyingagine posted is indeed a viable training system. That is my handle and here it is in use
Also if you care to read this thread:
http://www.rcuniverse.com/forum/m_10752510/tm.htm
it illustrates a rather non traditional type of trainer that I worked up that happens to use a .15 also and it works extremely well on sixty foot lines even in light winds. The key here is this airplane is not intended for aerobatics. It is a primary around the pole trainer and excells at that. Primarily because of the non traditional long lines and a very effective rapid adjusting line slider.
John
ID:	1791209   Click image for larger version
ID:	1791210   Click image for larger version
ID:	1791211   Click image for larger version
JohnBuckner is online now
Old 08-12-2012, 09:51 AM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JohnBuckner
John
JohnBucknerI sure hope you did not mind me posting that. I forgot where I pulled the pic from or I would have made sure I credited you I have now put a note on the pic. I have not yet made one of those but it sure looks like a heck of a good idea.
Now could you enlighten me on what a adjusting line slideris? Is that to adjust the leadout positions?
Ken
Old 08-12-2012, 11:56 AM
JohnBuckner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh absolutely not an issue and its a pleasure when someone enjoys a photo and uses a photo I posted. So thank you for the 'warm & fuzzies' this morning[8D]
I will dig up some more photos now in a few that illustrate a simple adjustable line slider.
John[8D]
Old 08-12-2012, 12:29 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seamus, If you choose the right buddy, it is not so bad.
Old 08-12-2012, 02:23 PM
JohnBuckner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here ya go Flyingagin, The line slider is simply a ply plate carring the leadout tubes and it will slide from a more normal slightly aft of the bellcrank center position almost to the trailing edge and allow a substancial yaw of the airplane to the outside of the circle.
The plate has a single imbedded bolt from the wingtip going through it in a long slot and its simply tightened with a wing nut.
When it is dead calm the slider can be set at full forward and the airplane does fine and very stable as well as a slow rotation on the sixty foot lines.
When the breeze comes up it takes just seconds to move more towards the trailing edge and the airplane has no problem at all in staying out on the long lines in fairly stiff breezes.
This is really just a variation on what the carrier guys (always wanted to try that but never got to it) do only their sliders once keyed by a momentary full up they move in flight to full rear for the extreme slow carrier landings. At least thats the way I beleve their setups work.
John
ID:	1791304   Click image for larger version
ID:	1791305   Click image for larger version
ID:	1791306   Click image for larger version
ID:	1791307   Click image for larger version
Reply
Display Modes
