Control Lines For all you fly-by-wire fanatics!
Venturi for OS Max H 40
Reply
Old 09-02-2012, 01:24 PM
Kiteflyer
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Venturi for OS Max H 40
Will the following venturi and needle valve assembly fit and work well on an OS Max H 40 being converted from R/C to control line?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCX05
http://www3.towerhobbies.com/cgi-bin...?&I=LXCR49&P=7
Kiteflyer is offline
Old 09-02-2012, 07:52 PM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Venturi for OS Max H 40
That venturi has an OD of 10mm but the H-40 needs a venturi of 13mm to fit the crankcase. The bore size of 7mm is OK although I wouldn't go any larger than that. The needle valve is also designed for a smaller venturi so wouldn't fit either.
downunder is offline
Old 09-03-2012, 08:30 AM
Kiteflyer
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the response, downunder.
Contact Us Archive Advertising Cookie Policy
