cox .09
RE: cox .09
For a TD 09, I had good success with a Jr. Flite Streak, and a 15 size Shark, also a #4 Easy for Old Time. A medallion will also do pretty well. I ran a Cox 7x3.5 prop. Sig Champion 10%nitro, 20% oil, half and half, and backplate pressure with oneway valve to the uniflow. Release at 14,500 to 15,000. Need about 2 oz fuel for a modern pattern. I used 55 to 57 ft eyelet to eyelet .012 lines. A medallion will probably need a little shorter lines.
RE: cox .09
I have a Medallion in a Mini Peacemaker.
Plan available on Hip Pocket http://www.hippocketaeronautics.com/hpa_plans/index.php
Nice for a relaxed flying session, on 42' lines.
Greg
Greg
RE: cox .09
THANKS FOR THE INFO GUY'S.HEY HAVE ANOTHER QUESTION? WOULD THE .09 MEDALLION WORK OK ON THE LI'L HACKER 1/2A FOAM COMBAT SHIP BY COREHOUSE?OR IS IT TO HEAVY?
HAS ANYONE HERE TRIED RUNNING A OLDER BRONZE BUSHED FOX .015 ON 1/2A BLADDER SETUP?WAS THINKING OF TRYING THAT ON A SCRATCH BUILT BALSA COMBAT SHIP LIKE THER LITTLE SATAN JUST ALITTLE BIGGER.ANY COMMENTS WELCOME.
JIM
JIM
RE: cox .09
ORIGINAL: jayseas
JIM
JIM
Do not use the Li'l Satan. It is WAY too small and is designed for a tank mounted 1/2A engine.
For a .15 you need the Junior Satan. I had a MAX-III .15 on mine but the Fox .15 should work fine. I would suggest .012x52' lines.
Good luck with it.
George
RE: cox .09
Goerge, it is one of the older fox .15.I think i will have to mock up the fox .15 with a bladder, and see how it performs.What do ya think about the Li'L hacker with a cox .09 Medalion and a bladder.
RE: cox .09
Jay,
No reason the Fox 15 won't work on bladder
EXCEPT!!!!!
They have a totally cr@ppy NVA, change it for one that works, like an Enya or OS and you'll be in business.
Greg
EXCEPT!!!!!
Greg
RE: cox .09
ORIGINAL: greggles47
Jay,
EXCEPT!!!!!
Greg
Jay,
EXCEPT!!!!!
Greg
RE: cox .09
ORIGINAL: jayseas
George
