Control Lines For all you fly-by-wire fanatics!
Rossi 09.20
Reply
Old 05-19-2013, 08:20 PM
bparker3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rossi 09.20
seen this motor on a website,wonder if anybody has usedone or seen one. it a 09 control line engine.its a ROSSI
bparker3 is offline
Old 05-20-2013, 12:24 AM
PWF63
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Rossi 09.20
What was that?
PWF63 is offline
Old 05-20-2013, 02:22 PM
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
controlliner is offline
Old 06-17-2013, 04:59 AM
qazimoto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bparker3
seen this motor on a web site,wonder if anybody has used one or seen one. it a 09 control line engine.its a ROSSI
Yes, I've ended up with two of 'em.
Strong little 09's just a bit better than a TD 09. Rossi have been making and selling them for over two decades I suspect.
One of mine has a head button for a 1/4" x 32 tpi standard plug. The other has a TD like head.
Should make an interesting diesel conversion. I know someone who had done this with some success.
Available from Planethobby at: http://www.planethobby.com/collections/2-09
Ray
qazimoto is offline
Old 06-17-2013, 05:11 AM
controlliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gaz, Does the piston have a ball/socket joint on the con rod?
Old 06-17-2013, 05:34 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The needle valve and body looks like a cheap alternative to other motors.  Too bad there is no tapered nut available.
aspeed is online now
Old 06-17-2013, 02:27 PM
qazimoto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: controlliner
Yes, I'm pretty sure it does even though I've never pulled one apart.
The position of the exhaust port is such that it shows no visible wrist pin so it's highly possible.
Ray
qazimoto is offline
Old 06-17-2013, 03:43 PM
greggles47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ray,
The el cheapo MECOA diesel head should screw straight in.
Do you want one?
Greg
greggles47 is offline
Old 06-17-2013, 11:54 PM
qazimoto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: greggles47
Ray,
Do you want one?
Greg
Thanks Greg, it would need the thread turned off but it may even fit.
Ray
qazimoto is offline
Old 06-18-2013, 05:36 PM
Wssmt41833
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: qazimoto
ORIGINAL: bparker3
Available from Planethobby at: http://www.planethobby.com/collections/2-09 and www.smtdistributing.com
Ray
Wssmt41833 is offline
Old 06-18-2013, 06:39 PM
qazimoto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the exploded view for both variants. I notice they're on sale for about USD75.
Ray
qazimoto is offline
Old 06-20-2013, 06:02 AM
controlliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The next question is whether the crank case has a bronze bushing or does the crank spin directly in the aluminum casting.
Old 06-20-2013, 03:53 PM
qazimoto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd bet on the crank running directly in the casting, especially since a bushing isn't shown in the exploded view..
Regrettably I'm not in a position to strip the running one down to have a look. It's in a model.
My NIB one only cost about $52 from Planethobby on a sale, so they're cheap and cheerful!
Ray
qazimoto is offline
Old 07-30-2013, 01:00 PM
skaliwag
skaliwag's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They run good. Though VERY LOUD. I have one converted to diesel, revs about the same on the same props but more efficient on the fuel burn. It also has a AP .061 carb mated to it.
skaliwag is offline
Old 07-30-2013, 02:12 PM
Gungadin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds very good Skaliwag. If you are making your own diesel fuel, what is the source for amyl nitrate and the ether ?
Gungadin is offline
Contact Us Archive Advertising Cookie Policy
