Wanted: Harter Proto B Speed Pan
Sorry Kirk, I don't have exactly what you are asking for but I do have a Royal Rodent Pan drilled for a K&B 35. It has the landing gear wire installed.
Cost = postage.
Clancy
Cost = postage.
Clancy
Harter B Proto pan
Yes, I know Barry...think he went out of the pan business a while back and Bill Highes now sells the Darp pans.
Unfortunately, Darp does not make a 20" proto pan like the Harter. There is then the issue if the hold-down bosses cast into any other brand of proto pan are in the correct location for the Regal Raider this guy wants to build. The wing is hard balsa with a spruce spar, so the hold downs can only go in one location at the center of the spar. Here is a Regal Raider I built a while back. Engine is a nib Torpedo 29rr, 61 Series.
Looks nice. I have been thinking of making a B proto for a while. If the bosses are the same where it is important, you could cut off the pan and use a half pan, just whittle out a rear filler. Or find a Harters somewhere obviously. Bill Hughes seems to do everything now. Busy guy.
