Control Lines For all you fly-by-wire fanatics!
Sig Banshee question
Reply
Old 11-29-2016, 12:27 PM
straitnickel
straitnickel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Banshee question
I'm no expert by any measure so, What would be the engine size and line length to make the Banshee easily controllable but sporty too?
straitnickel is offline
Old 11-29-2016, 03:23 PM
gene6029
gene6029's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LA .46, or Brodak 40 on 60' lines. Check out Stunthanger.com or Stuka stunt for lots of information on the Banshee.....Gene
gene6029 is offline
Old 01-18-2017, 11:00 PM
Donald Holder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Move the wing 2 inches forward is a big help on Banshee! Nose is to long! I have had several of them and this is good advice, also consider making it electric too.
Donald Holder is offline
Old 01-19-2017, 07:07 AM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew mine with a Fox 35 Stunt with the Hemi Head, stuffer backplate and tongue muffler. 4 ounce uniflow tank. I did shorten the nose 1.75" but could have shortened it even further, I had to add some tail weight to make it "pop" a little sharper. I flew on 60 foot lines.
Tom Nied is offline
Old 01-19-2017, 10:38 PM
Lou Crane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
straightnickel,
Check the other recommended comments.
The SIG Banshee was designed in the days of 6 1/4 ounce Fox 35s, w/out mufflers, on light wood props. Most modern engines weigh more, plus the weight of the muffler. (The nose is too long for today's power!)
By the way, the Banshee and Twister use the same basic wing. Both fly well, and can be tweaked to fly better with today's gear. Differences are in the wingtips and fuselage...
Adding weight to balance the modern power systems, and using a tamer engine runs into practical limits on the wing and tail layout. Best advice I see in other posts so far is to move the wing forward, Not simple, but keeps a good relationship with the tail. As long as there's room for a 3.5 or 4 ounce tank, most problems are answered.
It is still a simple profile, so dumping extra power into it is a sort of answer, but not (IMO) optimum. The location of the prop is not a major concern, except as it relates to the weight of the engine and room for the necessary tank. The wing is good - strength, airfoil and structure work. Weight overall is a concern...
{Personally. I don't care for the side view.) That gives you the opportunity to "kit-bash" to something you'd rather see at the other end of the lines. Very little would be needed - different "cockpit", different fin, etc. Just keep the flying surfaces near the original, given that you may move the wing further forward...
Good flier as stock, with a light engine and possibly going to 57.5' lines (eye-to-eye) instead of 60' eye-to-eye. Shouldn't need shorter...
Build light and straight, and don't weigh it down with a heavy finish. You'll enjoy!
Lou Crane is offline
Old 01-20-2017, 06:56 AM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If straitnickel is a new flier, and the concern is, can a new flier handle and fly "controllable" but still have a "sporty" plane. I would tend to say, yes. With mine I was able to teach my friend how to fly it on his first try, with me out in the center with him. Properly built, it will fly very smoothly. That's what a good stunt ship will do. Will it fly a pretty good pattern? Yes it will.
Tom Nied is offline
Old 01-25-2017, 08:54 PM
jayseas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Lou Crane View Post
straightnickel,
What about using the Banshee kit to kit bash it into a Ringmaster S-1 Specificaions?
Would it be a good candidate? I have a good McCoy 35 I want to use?
jayseas is offline
Old 01-25-2017, 09:07 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well if you have Banshee kit, why wouldn't you just build it as a Banshee?
Tom Nied is offline
Old 01-26-2017, 02:48 PM
jayseas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know Tom, why don't you tell me.
jayseas is offline
Old 01-28-2017, 03:05 PM
Lou Crane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I replied to this Q: as forwarded to me as email.
The gist: IF model is intended for OTS event flying, no. The Ringmaster wing has a swept forward trailing edge; the basic Twister/Banshee wing does not. That makes for a highly visible different wing, aside from the obvious area and airfoil differences.
Also, the S-1 Ringmaster has NO spars visible at the airfoil surface, where the Banshee/Twister wing is built with visible spars at the max depth of the ribs. Also highly visible. If the model is intended not for OTS events, but for a nice flying model for other purposes, Great!
Keep in mind that starting from a kit Banshee, the nose must be shortened or the wing moved forward to allow building a good model which does not need added weight to bring the CG to where it should be for quite good flying.
(Clarification) I merely wrote to keep the layout proportions like the original. Should have said that the proportions and relationships of the tail and wing need to be considered...
For enjoyment, go for it! If hoped to be accepted in competition events where reasonable fidelity to the original is a factor, no.
\BEST!
Old 01-30-2017, 04:07 PM
jayseas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
\BEST!
Thank you for your response Lou. I fly non competition, flying for fun/ sport.
jayseas is offline
Old 06-04-2017, 10:48 AM
redtail
My Feedback: (15)
redtail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flew my Banshee on 60' lines then as I entered RC, I converted the basic Banshee into an RC airframe, not changing the wing position, just reinforcing the wing. The radio gear/battery/servos were all mounted near the fuse, midway between the leading/trailing edges. Using a Fox 40 with a tuned pipe, and 3 radio channels, throttle, ailerons,, and elevator, it literally flew out of my hand on a vertical launch. Reading this post because I want to build a control line version again with a refurbished McCoy 35. Chic
redtail is offline
Old 09-18-2017, 06:44 AM
jpeggy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Banshee/Twister
Which is easier moving the wing forward or shorten the nose.........it would seem to shorten the nose would be easier....
jpeggy is offline
Old 09-18-2017, 04:32 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shorten the nose. I had a Fox .35 Stunt on mine and I wish I shortened it to the max the tank I had would allow.
Tom Nied is offline
