Control Lines For all you fly-by-wire fanatics!
299 KM/H at the BMFA Power Nats [UltraHD/4K resolution]
Reply
Old 09-27-2017, 09:46 AM
DominicM
DominicM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 299 KM/H at the BMFA Power Nats [UltraHD/4K resolution]
Wasn't aware these projectiles could get THAT quick. I guess having a race tuned two stroke, very little fuel onboard to minimise weight and one wing helps ! Filmed in UltraHD / 4K. Watch out for the super slo mo at the end...it's still fast.
DominicM is offline
Old 09-27-2017, 07:09 PM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As the commentator said after the flight, that was Paul Eisner who's been setting records for years. Not bad for a 2.5cc engine and zero nitro fuel . The single wing is used to cover as much of the lines as the rules allow because most of the drag comes from the lines, not the model.
downunder is offline
Old 09-27-2017, 08:16 PM
DominicM
DominicM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn't have thought about the lines causing drag. Thanks. Good to know.
DominicM is offline
Old 09-28-2017, 08:37 AM
grotto2
grotto2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dominic-
Just as a rule of thumb, an object with a cylindrical cross section traveling through air has about ten times the drag as an airfoil shaped object of the same thickness.
So line drag is indeed very significant in C/L.
Also note that C/L planes require substantially bigger engines than similarly sized R/C planes for the same reason.
grotto2 is offline
Old 09-29-2017, 08:31 PM
DominicM
DominicM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. I'll add that info to the vid description. Appreciate it. Cheers.
DominicM is offline
Contact Us Archive Advertising Cookie Policy
