enya .35
enya .35
Is there anyone here that has a enya .35 (5224) that has the square venturi replacing the carb?I beleive they came in 3 different sizes.I believe the #1 is hi performance if that's how you discribe it.Well what i'm looking for is the inside diameter of the plastic venturi so i can make my own, the one's i have found, they just want to much money for a small piece of plastic.
Jim
Jim
IL
RE: enya .35
The #1 is the smallest bore- 6.83 MM .269" "H" drill. The #2 is 7.37 MM .290" "L" drill. The #3 is the power venturi, read poor suction feed, 8.38 MM .330" 21/64 drill.
Send me a note at [email protected] if you want a .pdf file with all dimensions.
Pat
Pat
