Control Lines For all you fly-by-wire fanatics!
049 racer
Reply
Old 03-04-2010, 12:31 AM
skaliwag
skaliwag's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 049 racer
Here's some reading.
http://en.wikipedia.org/wiki/Washout_%28aviation%29
Think of it as a twist in the wing like a prop... So the tip "digs in" = down.
skaliwag is offline
Old 03-04-2010, 08:30 AM
Fytch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmm, anyone has pictures of a downwashed wing? i know wad the wiki is talking about but i have no idea on how to execute it..
by the way, i've started on the fuselage!
ID:	1390916   Click image for larger version
Fytch is offline
Old 03-04-2010, 10:46 AM
Fytch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have another question, does the inboard flat bottom airfoil and the outboard semi sym airfoil help much?? it reduces the amount of tip weight needed?
and guys, do u reckon i should sandwich one side of the fuselage with 1/32 ply? or 1/64?
thanks a bunch guys!
Reeve
Fytch is offline
Old 03-04-2010, 03:31 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your tank looks good. Racers need to be strong to survive the stresses of getting them down and into the hands of the pitperson. What I would do on your wing is, on the last maybe 3 in, move the trailing edge up until you have an inverted airfoil at the tip. The wing shaping is to help keep the airplane on the end of the lines when you go into strong wind or up high to pass. The wing weight is, I think, still needed, particularly for the take off. On the take off with conventional engine turning counterclockwise and airplane flying counterclockwise, the airplane tends to torque roll into the circle on release. Your pilot should be whipping the airplane to keep it from coming in. With an otherwise good airplane and experienced pilot, this is not a real problem. I've seen several photos of racing airplane coming out of the pit, always with inner wing down a little.
Jim Thomerson is offline
Old 03-05-2010, 09:19 AM
Fytch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jim could u please explain wad do u mean by moving the trailing edge up?, by the way, could u see if wad u meant about the wheel being 15 deg infront of the c.g is correct in my previous drawing?
thanks!
Fytch is offline
Old 03-05-2010, 12:56 PM
  #31
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are making a symmetrical airfoil on a 1/4 sheet wing, the trailing edge goes down the center of the back side of the wing. So if you move the trailing edge up at the tip, you get washout. On your drawing, the 15 degree line needs to go through where the wheel touches the ground. It won't hurt to put it a little far forward, and bend it back if you get bouncy landings. My last mouse racer was a profile Goodyear racer with the wheels way far forward of where they should be. The guys all criticized it: however, it landed and took off beautifully. I used a set of aluminum landing gears which weren't made right and thought I would have problems, but did not.
