Fox Stunt Plug
Fox Stunt Plug
Has anyone tried the new Fox Stunt plug? It is supposed to take away the Fox burp on the .35 stunt.
http://www.foxmanufacturing.com/inde...95bde367042746
RE: Fox Stunt Plug
ORIGINAL: controlliner
I buy a card of Thunderbolt plugs every so often, and use those in the old Foxes (or Max-S 35s, my last McCoy has a broken lug)), when I want to hear a four-cycle sound again. (And I often wish I had something left over that was slightly larger, without being "too large", to get out an old G21/46 and run it. Those really had a very sweet sound, unmuffled, four-cycling.)
RE: Fox Stunt Plug
I've been running Fireball hot plugs in most stuff lately with few problems, but only because I got several cheap a few years ago. For the engines that run OK with a 75/25 FAI mix they work well (ST G21-46 and OS FP .35's I have seem very happy with the 75/25 FAI/Fireball hot combo)
I had been running Fox standard longs in the stunt .35's previously but on a low 5-7% nitro mix the Fireball hot's seem better. I've had good results with the Sig R/C long plug in the stunt .35 in the past too.
