Control Lines For all you fly-by-wire fanatics!
I'd like to compete, what class should I start?
Reply
Old 08-02-2010, 06:52 PM
iflyg450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I'd like to compete, what class should I start?
Let me say I freaking love flying U/C. There is an event near by, however not sure were to start. I have for planes a Nobler powered by an OS 46LA-S and a PDQ Yak-9 powered by an OS 25LA-S. So I was thinking of trying OTS profile with the Yak. Would this set up be competitive? Also what class would the Nobler fall into. The event is in Saint Augustine, FL in January
iflyg450 is offline
Old 08-02-2010, 09:29 PM
stuntflyr
stuntflyr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: I'd like to compete, what class should I start?
The Yak is Old Time legal I think and the Nobler is Classic legal. You can fly the Nobler in PAMPA Skill Class events also. If you can do the whole Pattern you could just start in Advanced. You will be put to the test all at once, but driven to improve rapidly too.
Good luck and have fun.
Chris...
stuntflyr is offline
Old 08-07-2010, 02:17 PM
Derek Barry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: iflyg450
I assume you are talking about the King Orange contest?
Derek Barry is offline
Old 08-07-2010, 03:31 PM
iflyg450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, not sure what class to start with. I know my PDQ Yak fits into OTS profile and the nobler goes OTS classic I think. I have been thinking of building something to compete in CLPS Beginner just note sure what plane would be best
iflyg450 is offline
Old 08-07-2010, 04:39 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I were going to start flying PAMPA beginner today, I think I would build a Sig Twister. Probably the Brodak Oriental is as good and simple a full fuselage airplane as you can find. I flew a Sterling Yak 9 with a McCoy 35 in OTS for a while. It would be fine for Beginner. I built mine without working flaps.
Jim Thomerson is offline
Old 08-08-2010, 12:41 PM
DaveSR71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
iflyg450
Twister would be good start. Wish that Sig still made the Banshee.
I think Brodak makes the old Midwest Magician now and their P-40 could be the old Midwest P-40 Magician based profile.Not sure.
They have some other profile stunters and numerous other.
The Nobler can still be competitive in modern stunt.
If you already fly well then something with flaps so you can learn trimming as for me this is harder than learning to fly the patterns.
Some where floating around the net is a Stunt Plane trim chart that is helpful.
I do not remember the Sterling Yak or F-51 having flaps. Will try to look at a kit tonight.
Adding narrow flaps would possibly make good flier.
What ever you use here is link to the beginner pattern.
http://www.brodak.com/stunting.php?id=3
After making judged take off and 2 lap judged level flight make sure you make 2 more laps before wing over!!!! (2 laps between each maneuver.)
Here is Old Time pattern
http://www.brodak.com/stunting.php?id=4
And then:
http://www.brodak.com/stunting.php?id=5
When you find that your good flying airplane drops the ball when put to the pattern its time to learn trimming.
DON'T GIVE UP TRIM IT!
This is where I am in the obsurd task of combining my C/L combat/racing skills with R/C scale skills while avoiding mayhem and disaster.
The Midwest P-40 took months to trim and years of major mods to get to fly decent at all but that's another tale. I is a Pattern PIG and difficult and has been a good teacher because of its problems.
The Chip was easier to get good flights and the big Yellow thing has flown absolutely mind boggling perfect every flight and is more airplane than I am pilot.
David
DaveSR71 is offline
Old 08-21-2010, 07:32 AM
fokkit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been slowly learning the pattern with a "Gotchastreak" and can really recommend them. Sort of a big Flightstreak. (53") Simple build which can be built over a weekend if necessary, no flaps but turns on a dime and squares are no problem. Mine's Electric but anything from a .30-.46 wet motor would pull it around no problem. Spare wing cores etc are available in the event of smacking it with the planet. Mine is 44oz fully loaded with battery and gives 6 minutes flights.
For reference..
Motor Scorpion 3014-16
ESC Phoenix 45
Timer Will Hubin FM9
Battery 3s 4000mah ~2800 used per flight
TTFN
John.
fokkit is offline
Old 08-21-2010, 04:32 PM
Lou Crane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ifly,
The Stunt classes are pretty well spelled out in the AMA Competition Regulations. I don't know if the KOI uses straight AMA Rules or has some special variants.
To start in competition, forget about it being competition. ...for a while anyway... See it as an opportunity to show off your skills at the same figures as others are flying. And, most important, as an opportunity to get together with a bunch of other ukies.
The AMA CLPA Beginner Pattern is drawn in the Rulebook. You don't even need to be an AMA Member to look into the rulebook online (at www.modelaircraft.org ) Beginner Pattern is simpler than the full pattern, so it is worth a lookover... You'll probably need to be an AMA member to enter; membership apps are available from the contest officials, if necessary...
Another experience of competition is being ready to go on the circle when called, or as posted on a scoreboard flight order, crank it up, get it up, and fly. It feels good to have that confidence.
You'll learn more than you think possible by mixing with the other fliers. CL people are almost always wide open friendly and helpful. Don't be afraid to ask for help, within reason, of course... If you see a guy really trying to get his "thing" keyed real fine, an interruption might not be welcomed. A few take it more seriously. That's what they enjoy about it.
Enjoy! that's what it is all about!
Lou Crane is offline
Contact Us Archive Advertising Cookie Policy
