RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Control Lines (http://www.rcuniverse.com/forum/control-lines-231/)
-   -   A Ringmaster underway (http://www.rcuniverse.com/forum/control-lines-231/11283439-ringmaster-underway.html)
Don B.H. 11-01-2012 11:50 AM
1 Attachment(s)
Well I wanted to build another 35 size plane and there are none better than the Ringmaster. I came across this OTS Legal Ringmaster and I ordered it on line. Boom, it was here in no time. I started the build last week and I am very happy with the kit, she is starting to take shape.
Don B.H. 11-01-2012 12:03 PM
RE: A Ringmaster underway
1 Attachment(s)
By Friday she was well underway and I wanted to build the wings a little stronger so I added sheeting to the rear and capped the spars.I also used the sliding leadouts provided. I did get some covering done to the wing but then the superstorm hit and power was out.
BtnFlyGuy 11-01-2012 02:03 PM
1 Attachment(s)
I got my first C/L flight in last month after decades out of the hobby and I'm pleased that it was with a borrowed Ringmaster (pictured). (Thanks Dick!) I got so dizzy I had to give the plane back before the tank ran out, but the appetite is truely whetted. I have a RIngmaster in the box that will be ready for the spring.
jcralley 11-01-2012 02:26 PM
Hi Don,
Looking good! The extra sheeting and cap strips are probably unnecessary but if you do not want an all out competition OTS model they will not matter (it will not be OTS legal with those modifications). The best flying Ringmasters come in at 24 to 26 oz (the best I have ever done is 28 oz and it flies fine) so try to keep the weight down as much as you can.
Keep us posted on your progress.
John
Don B.H. 11-02-2012 11:43 AM
1 Attachment(s)
Some one on another forum said the wings are weak and don't hold up so I came up with this.
Not legal I just add 1/16 to each side.
Well I got some covering done.
jcralley 11-02-2012 12:04 PM
Quote:
ORIGINAL: Don B.H.
Someone on another forum said the wings are weak and don't hold up so I came up with this.
Yes, the outboard wing on S-1 Ringmasters has been known to break near the root in violent maneuvers especially in a strong wind. I have seen several do just that. However, you can strengthen the wing internally and still have an Old Time Stunt legal Ringmaster. Fiberglass, carbon fiber veil and plywood have all been used to beef up the wing root (sometimes in combination). For myself, I used carbon fiber tubes to stabilize the the outboard wing root after people told me the wing was flexing during square loops.that seems to have worked just fine. I had to do some major surgery on the wing to do the modification which could have been easily done during the original construction!!
When you sheeted and cap striped the wing you changed the external wing configuration and made the model no longer OTS legal.
John
Don B.H. 11-05-2012 08:44 AM
Live and learn..
Oh well she will be a fun fly ship... My Shoestring Stunter is all stock and by the book So that should be OTS legal I think.
:DMy ringmaster twin just arrived and that will be my winter project
JECraig 11-05-2012 12:29 PM
http://www.brotherhoodofthering.info...egory-view.asp
Join us for next years Ringmaster Fly-a-thon October 2013.
http://www.brotherhoodofthering.info...=8&start=1
Don B.H. 11-05-2012 01:54 PM
That is why I built the Ringmaster Jr the Ringmaster and I the Ringmaster twin and another Jr. to build. I hope to have at least 4 people flying Ringmasters.
Brother Don
paw080 11-05-2012 02:10 PM
Quote:
ORIGINAL: Don B.H.
Live and learn..
Hi Don, The Goldberg profile and other models in that series(Buster, Cosmic Wind, Shoestring) are
not OTS legal. They are legal for Classic stunt. Actually, I think the mods that you did to the
Ringmaster model will result in a better flying model. If the competitive spirit overtakes you,
your Ringmaster can fly in the Profile 40 event.
Tony
PWF63 11-06-2012 02:40 AM
Hi Guys<div>
</div><div>I'm reasonably new to this forum just touching bases with a few threads.</div><div>
</div><div>I had the pleasure of attending this years Sydney Australia leg of the Ringmaster fly-in</div><div>hosted by My home club, Kuringai Model Fying Club.</div><div>I give a fellow club members  Ringmaster  a few flights and had a ball.</div><div>Just got a plan printed out to build 2  Ringmasters for next years fly-in.</div><div>One will have a OS Max H40 for power. Combat style....lol</div><div>The other will be more tame with a Enya SS30.</div><div>Looking forward to more Ringmaster discussions.</div><div>
</div><div>Cheers</div><div>Fredo </div>
Don B.H. 11-06-2012 10:54 AM
1 Attachment(s)
Well she is almost there.
I need a good day for a test flight...
If only I was Down Under, Eh.
Don B.H. 11-09-2012 01:51 PM
1 Attachment(s)
And now for the Ringmaster Twin
Don B.H. 11-13-2012 03:00 PM
Well I had the Ringmaster out and got her up yesterday. SWEET! The grass was a little high so we had to hand launch and then she tracked nice and smooth, climbs and dives crisp and clean and then I went for the inside loops and outside loops. She pulled thru these and still held line tension.
No wing overs, figure eights or four leaf clovers yet so more latter.
Don B.H. 11-14-2012 08:36 AM
1 Attachment(s)
The Twin is coming along nice.
I put it all together to check the fit the wing still needs sheeting on the center section. I always put together and take apart many times...
steve111 11-15-2012 05:40 PM
G'day Fred, the SS30 is a great choice, and will have a comfortable excess of power (I'm using one in a 520 sq.in, 37 oz model, and it's plenty even for that). As for the Max H40 version - this I have to see!:D
Cheers
Steve
PWF63 11-15-2012 11:01 PM
1 Attachment(s)
Quote:
ORIGINAL: steve111
Cheers
Steve
Hi Steve
Mate, I'll have to have the H40 Ringmaster ready for the Old Phartz next year for you to have a fly of it.
Here's the engine just itching to get into something quick. It'll be a Ringmaster like you've never seen one...lol
<br type="_moz" />
steve111 11-16-2012 08:53 PM
It'll be worth making the trip for that alone....
Clean 11-18-2012 11:57 AM
Thst is a sweet looking twin.
Don B.H. 11-28-2012 01:50 PM
1 Attachment(s)
Got 2 OS .15LA and reworked them for C/L
I bolted them to some wood and fired them up, man did they sound<u> sweet</u> together......
GallopingGhostler 11-28-2012 03:24 PM
1 Attachment(s)
Okay .... here is the beginning of my Ringmaster build, a half-A Ringmaster Gee Bee Z, on 3/16 in. (5 mm) paper covered foamboard. The patterns have been laid out on the board, awaiting temporary fixing with a glue stick and cutting. At 19 in. (483 mm) wingspan, it will be powered with an A.C. Gilbert .074 Thunderhead engine. The 3 in. (76 mm) dia. cowl is from a GNC vitamin supplement bottle. The plan comes from a scaling of the Ringmaster Jr. reduced quarter sized detail on the original Sterling plan. The fuselage is adapted from the late Keith Laumer's Gee Bee Z profile CL plan. The Ringmaster's cockpit and rudder are retained.
The A.C. Gilbert powerplant has already been prepared with over a half hour bench break-in time. She's eager to run. [:-]
It is not OTS legal, it is anything but illegal, it is a variant.
Who said the Granville Brothers didn't try CL, or that A.C. Gilbert didn't try 1/2-A Proto racing? The large cowling will add streamlining, as you can see. :D
Do you think I will be able to get away with it, flying it at next year's Ringmaster Brotherhood Fly-A-Thon? [&:] Comments? [8D]
dennis 11-28-2012 04:52 PM
1 Attachment(s)
Quote:
ORIGINAL: Don B.H.
Don,
I know that you have seen this on the BOTR site but for those who don't go there I'm showing them what it looks like complete. You are really going to love that model when done.
Dennis
Don B.H. 01-13-2013 04:17 PM
Well I got back to working on the Ringmaster twin and she is looking good to me. <font color="#00265e" size="2">dennis</font>I have seen your twin on the Broterhood of the Ring site.
Wheredo you fly? I live in the upper Bay Area of MD about 12 miles from the PA line and I was thinking of going to Brodaks this year.
A pair of Ringmaster Twins would besweetat the Brodak fly-in.
GallopingGhostler 01-13-2013 04:51 PM
Dennis, I like your checkered RM Twin, really nice. Bet those engines sound really sweet when running in unison. [8D]
dennis 01-13-2013 08:07 PM
Quote:
ORIGINAL: PWF63
Quote:
ORIGINAL: steve111
Cheers
Steve
Hi Steve
<br type=''_moz'' />
I haven't read all of the threads but as to having the fastest gonzo Ringmaster your a little late and a lot low on power. Dee flew one with a Nelson 40 and was well over 100 MPH. Your 40 wont get much over 65/70. Still you will have one fun model to burn the circle with.
Hav
