36" spitfire Mk 1X thread build
Join Date: Jan 2010 Location: UK, Medway, Medway Posts: 4 Distance from you: 0 km | 36" spitfire Mk 1X thread build <hr size="1" style="background-color: #a7a7a7; color: #a7a7a7" /> Hi all I have decided to build this spitfire from the MW Mag. It was in the May 06 edition, ive tried to look for thread builds on it as i have stumbled at the first hurdle regarding the wing, Dihedral wing braces, there is not much mentioned in the plane or book, no pics nothing, so i am just going to try my best. I thought id up load some pics of my progress to ask you pro's, What shall i do? I have build both sides but differently, i relise that the braces will give the dihedral but will it be strong enough [IMG]
shall i go for half a rib either side of the rib? or do a full rib and cut out the brace afterwards? I am converting it to electric aswell | ||||||||
Join Date: Jan 2010 Location: UK, Medway, Medway Posts: 4 Distance from you: 0 km | 36" spitfire Mk 1X thread build <hr size="1" style="background-color: #a7a7a7; color: #a7a7a7" /> Hi all I have decided to build this spitfire from the MW Mag. It was in the May 06 edition, ive tried to look for thread builds on it as i have stumbled at the first hurdle regarding the wing, Dihedral wing braces, there is not much mentioned in the plane or book, no pics nothing, so i am just going to try my best. I thought id up load some pics of my progress to ask you pro's, What shall i do? I have build both sides but differently, i relise that the braces will give the dihedral but will it be strong enough |
What shall i do?
but which is correct
