Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
middle stick
Reply
Old 02-19-2012, 12:00 PM
AngelosLar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default middle stick
I would like to ask if this plane was indeed called middle stick. it was build by my late father around 1985. i would like to restore it to flight condition while waiting for some wing cores of another plane to arrive. if someone recognizes this bird, what size of engine did it used to have?
ID:	1729150   Click image for larger version
ID:	1729151   Click image for larger version
AngelosLar is offline
Old 02-19-2012, 12:09 PM
AngelosLar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: middle stick
ok found it with some net search . sorry for the post. it was made by graupner... will post some pics after its done and had engines in the .40 range
Old 02-20-2012, 04:43 AM
jlingrel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew a Middle Stick in Germany back in the late 70s. Wonderful little plane with an OS 40 on it.
John
jlingrel is offline
Old 02-20-2012, 02:01 PM
AngelosLar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice. at least i will have something to expect now john. The only problem is that it does not need recovering. basically it needs scrapping and building a new one... according to my mother it was build around 1976 to 1978 not 1985. I started stripping the plane from its time worn cover and i had a disturbing suprice. All of the plane was soaked in a yellowish sticky, oily wet substance. I dont know if it is fuel from the old days, water,chemicals or even a special kind of mold that attacks balsa hehehe.. i dont know. it was a mess. so i decided to start taking notes , marking outlines and shapes on a cardboard paper while i was dissasebling the plane tottaly! Its easier to build a new one (i have to replace EVERYTHING anyway on the old) and thats what i started to do. the cores of the other build arrive in 4 days according to the maker so i got 4 days to finish the fuselage . Here are the pics of the fuse soaked/damaged by that sticky/oily substance:
ID:	1729612   Click image for larger version
ID:	1729613   Click image for larger version
ID:	1729614   Click image for larger version
Old 02-20-2012, 02:06 PM
AngelosLar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and here how the middle stick is now after MY attack ....dont worry all formers,doublers e.t.c that were removed were used as templates and saved
ID:	1729620   Click image for larger version
Old 02-20-2012, 02:34 PM
AngelosLar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the formers were made out of a 3mm balsa and 1 mm ply sandwich so i decided to go exactly that route! in a long afternoon/night i have cut most of the formers, cut the fuse floor and started assembling on it. i layed the fuse floor flat on my board and tack glue it on. Here are the pics of the assembly so far . I even found the tx that he used to fly the plane . an old monster long forgotten by humanity
ID:	1729645   Click image for larger version
ID:	1729646   Click image for larger version
ID:	1729647   Click image for larger version
ID:	1729648   Click image for larger version
Reply
Display Modes
