Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
trailing edge of aileron repair need help
Reply
Old 05-10-2012, 08:35 PM
HobbySites
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default trailing edge of aileron repair need help
how and what would you use to fix the trailing edge of the aileron in the pictures? the guy who built this plane that the wing is from suggested bondo or some other type hobby of filler ( i cant remember which one he said) and then covering it with a piece of covering. the only problem that i have with the bondo is i can not seem to find white bondo i can only find red and i think the red would show through the white monokote covering. what do you guys think?
ID:	1761412   Click image for larger version
ID:	1761413   Click image for larger version
HobbySites is offline
Old 05-10-2012, 08:44 PM
pimmnz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: trailing edge of aileron repair need help
It's tiny, seal it up with a smear of epoxy then cover with a scrap of film. No other work required.
Evan, WB #12.
pimmnz is offline
Old 05-10-2012, 09:26 PM
HobbySites
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks pimmnz. that would work but i was trying to get the cleanest look possible to keep the plane looking the best it can. this wing is from a 50cc plane and lookes like it was chewed on by a mouse or small rodent wile it was sitting for a couple of years. if you click full size on the first picture that is almost the exact size of the damage that was done witch is about an inch long by maby a 1/4 inch deep.
Old 05-11-2012, 07:21 AM
Prairie Mike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take a piece of 1/4" balsa and cut out the aileron and fit the stick, sand & cover. Or maybe you could use some filler and sand & cover. I agree wit pimmnz; just seal it, cover, and go fly.
The only way I know to keep it pristine is to hang it in the living room (that'll get HER blood boiling, but that's why we married 'em)
Prairie Mike is offline
Old 05-11-2012, 12:19 PM
daveopam
Moderator
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would peel the covering on both side back. Cut out the bad section. Cut a balsa patch and thin CA it in place. Then sand it down. Then patch over the new piece with white monocote. Finally lay back down the covering you peeled in step one. This would give you the cleanest job. Although there is something to be said for just covering over it.
David
daveopam is offline
Old 05-11-2012, 03:39 PM
biam
biam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ya, what he said! Cover it and fly it till you crash it! Then this minor hickey will be totally forgotten!
biam is offline
Old 05-11-2012, 08:37 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Elmer's Carpenter's Wood Filler and then sand flush and recover.
Charlie P. is offline
Old 05-12-2012, 03:03 AM
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balsa Lite filler comes in white as well as balsa color.
http://www.hobbico.com/accys/hcar3400.html
SrTelemaster150 is offline
Old 05-12-2012, 04:58 PM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
light weight spackle from the local big box store. same as the hobby stuff, just less money. sand flush, a few drops of ca to harden and recover.
ken
kenh3497 is online now
Old 05-13-2012, 12:11 PM
HobbySites
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you all for the ideas on how to fix the aileron i have it fixed now and it looks like nothing ever happened to it.
Old 05-14-2012, 10:06 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: HobbySites
That's what we like to hear!!!
Reply
Display Modes
