Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
MOTOR MOUNT REPAIR
Reply
Old 07-24-2012, 11:28 AM
nitro208ca
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MOTOR MOUNT REPAIR
This post is more or less your opion on repairing a motor mount (firewall)on a foamy.
I know how to fix motor mounts on foamies,but i have been having bad luck with them.
The type of motor mount that im talking about is the one's that are just a flat piece of plastic that is attached to the main body from the manufacture.I glue up the mount , which is just a flat piece of plastic with one hole in the center and for other holes for the mounting screws.I have used ca(foam safe), expoxy, and a new type of glue that works great on the rest of the plane called fabric tac).Some of you might call it the firewall.
The thing is i get it all glued up( i do wait 24 hours to make sure glue cures), put on the motor and go flying.I get to about may-be 5 - 6 flights and the motor mount(firewall) comes loose and the motor starts to wigel alot. I do use clamps and such different things to hold it in place till glue cures.
Iwant to know if you guy/gale's have any tips and tricks you do and what kind of glue do u use
nitro208ca is offline
Old 07-25-2012, 04:38 AM
RC MANIAC119
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MOTOR MOUNT REPAIR
Replace the plastic firewall with a piece of plywood.........you can then use servo screws to
mount the motor, and it will stay in place, until you dork it!!!
RC MANIAC119 is offline
Old 07-25-2012, 07:32 AM
WaffleMan
WaffleMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could try Gorrila Glue
WaffleMan is offline
Old 07-25-2012, 07:43 AM
RC MANIAC119
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i don't think Gorilla is the problem...........the plastic motor mount does NOT have enough material to grab.......so the screws keep coming out!!
Old 07-25-2012, 11:24 AM
nitro208ca
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm trying to fix the firewall that is already in there.It is letting go around the edge's of the firewall.I know about the balsa ply option.I am hoping for some kind of fix for the origanal piece that is there.If i have to use the ply i will
Old 07-25-2012, 12:07 PM
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let see a Pic if you can . maybe some screws or dowel pins in the right places may help. You can make L shaped brackets to hold it in place.
Live Wire is offline
Contact Us Archive Advertising Cookie Policy
