Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Sig Rascal RC wing dihedral
Reply
Old 03-05-2013, 10:04 PM
H2omember
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Rascal RC wing dihedral
I have a used 3 channel Rascal RC that was stripped of gas motor and electronics but I redressed it with new electrics and went to the field where it flew like a 3 legged dog on ice skates. Almost crashed getting it back on the ground. Upon closer inspection found the dihedral was different on both wings as well as the cord line. Probably explains why it was available at a garage sale. I separated the wings by cutting out the center section. Both wings are good, it was just a bad joining by the original Builder. I want to rebuild the center section and rejoin the wings but I need some advice as to what angle I cut the dihedral brace. I'm using some 1/16 basswood and will epoxy it in place followed with some tiny wood screws for extra reinforcement. I,m thinking some thing like about 4 degrees of angle but don't know if that's too much or not enough. Looking for a gentle stable flyer. Any advice is appreciated.. Thanks
H2omember is offline
Old 03-06-2013, 09:08 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig Rascal RC wing dihedral
Can you give me the wingspan? I have the Rascal C with the 49" wingspan. The dihedral is NOT listed in the assembly manual or the plans. If yours is the same I can measure the wing with one panel flat and measure the height of the apposing wingtip. Just one thing you did need to check first. If your wings were built correctly the should have some washout at the tip. This helps the handling and if it is missing you have another problem. The Rascal C while small was never intended for a beginner builder which explains a lot on your airplane. Let me know what you find out and I'll see if I can help you.
FlyerInOKC is offline
Old 03-06-2013, 12:55 PM
H2omember
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you, I appreciate the offer. The wingspan is just under 49", more like 48 1/2". You mention wash out, and I'm guessing you mean that the outside ends of both wingscurl up a little bit on the leading edge for the last 3" or so? I can try to send you a picture if I'm not explaining it very well.
Old 03-06-2013, 01:11 PM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That was exactly what I was talking about when I mentioned washout but it should be the trailing (back) edge not the leading (front) edge. The curve keeps the wingtips from stalling earlier than the rest of the wing. I would say you have a Rascal C.
Old 03-06-2013, 04:10 PM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just measured my wing. Lay the wing with one panel flat on the bench/table the other wingtip will be 5" off the table at the centered.
Old 03-06-2013, 10:17 PM
H2omember
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, so if I understand you correctly it's 5" across the length of the whole wing or accounting for the center piece about 2" from wing root to wing tip.  According to my engineer friend that should be about a 5 degree lift from center to tip. He'll calc it out in AutoCad and confirm for me. Thank you so much for your help.  Also, I just checked the washout and it looks like an equal lift across the front to back edge from tip to about 3" or 4"  back. Does the sound right for the Rascal C, that's what the decal on the wing calls the plane?
Old 03-07-2013, 06:15 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a crude drawing of what I was talking about. I'm guessing without seeing them your wingtips are correct. If you could stack the wing panels bottom to bottom and take a picture from the tip end I could tell you. And you are correct you have a Rascal C. The design was based off a Top Flite airplane from the 40s.
Old 03-08-2013, 08:00 AM
H2omember
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what the tips look laid bottom to bottom as you suggested.. My engineer buddy did the dihedral calc and it come out as 6 degree. He drew up the brace in AutoCad and ill cut it tomorrow on the band saw and sand shape it to final form. [img]webkit-fake-url://8E711104-E368-4EE8-96AA-4CA87BF8CDD7/imagejpeg[/img]
Old 03-08-2013, 08:24 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can't see it you need to upload it as a jpg.
Old 03-10-2013, 07:44 AM
H2omember
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was a jpeg but maybe a little too large for the website or maybe because I was sending from the iPad. Anyway, here it is again cut down in size and still jpeg format.
Old 03-10-2013, 07:18 PM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Judging from the picture the wingtips look correct! Let me know if you need any additional information and good luck!
Reply
Display Modes
