Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Firewall repair
Reply
Old 07-04-2013, 06:43 PM
p3arljam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Firewall repair
i have a damaged firewall i need to remove it whats the best way i would like it out in tact so i can make a template any thoughts?
p3arljam is offline
Old 07-05-2013, 04:14 AM
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Firewall repair
There is no 'simple' way to do it but if it were my plane, I would try a little gentle heat from a heat gun to see if I could pry it loose.
Another thought... is this an ARF? If so, can you get into the back side of the firewall? I am wondering if it's put into place with some hot melt. Again, you could use heat (but not as much) and pick the chunks of hot melt off with a dental pick or something similar. Home Depot has something that could be used:
http://www.homedepot.com/p/Lincoln-E...k#.Uda3z7TD-Ag
You can find this at other home centers and woodworking stores as well, I'm willing to bet.
I am sure that there are other really good ideas out there as well. When you reinstall the firewall, use 30-minute epoxy and take the time to fuel proof the bare balsa that is now exposed.
Just my $.02.
Bob
N1EDM is offline
Old 07-05-2013, 07:51 AM
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 use the heat gun. Arf's are put together with hotmelt glue and I have done this before. Just keep heating it until it comes loose
raptureboy is offline
Old 07-05-2013, 08:02 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have pushed them back level and scabbed a new piece over the top. But it should come out with a little heat and some patience.
David
daveopam is offline
Old 07-10-2013, 12:37 PM
Calvinman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Pearljam, If the heat doesn't work a dremel tool and lots of patience.Calvi.
Calvinman is offline
Old 07-10-2013, 06:52 PM
KitBuilder
KitBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Push on it from the rear with a board or tile in front to help "flatten it out.... There is your template - prior to removing it.
KitBuilder is offline
Contact Us Archive Advertising Cookie Policy
